Results 1 to 5 of 5
Thread: 1962 Hawk Heater Hose
    Speedster Member
    Jul 2005
    Poteau, OK
    193
    Blog Entries
    1
    I have installed new blower motor and 4" heater hose under the right fender and am wondering if there is a wheel well plate that protects the hose and blower from rain, mud and debris thrown up by the right front tire. chet445
    Dec 2005
    Ferndale, WA, USA.
    28,768
    No only the Left side has a Cover for the Pedals etc. nothing in either Fender, some years the Fan Motor was undercoated for some protection, if you are using the correct wire and cloth reinforced rubber Duct Hose, and not a Dryer Duct Hose, it will survive just fine.
    Jun 2015
    Tracy / Goleta Ca.
    1,011
    Correct, it just hangs out there in in the weather and dirt and, surprisingly, survives.
    Aug 2016
    Elko NV
    791
    It's not authentic, but I used the aluminum flex pipe, then sprayed with undercoating. It fits, and looks good, and should be a little more durable. The under seat heater works quite a lot better than I had imagined.
    Speedster Member
    Jul 2005
    Poteau, OK
    193
    Blog Entries
    1
    Thanks guys. I looked and figured there was nothing to protect the system.
