Results 1 to 9 of 9
Thread: COVER for Hole in Bell Housing
    Speedster Member
    Oct 2013
    Butler, PA
    122
    I have a 58 Packard with air-cooled Flight-O-Matic. On the right side of the bell housing, there is an approx. 3" x 4" hole. Is this an air passage to cool the convertor or ? It is currently open and un-covered, is this normal ?, or should there be a screen or metal cover over the opening ? If it requires a cover, does anyone have a part #, or have one to sell ? Thanks, Dave
    President Member (S)'s Avatar
    Aug 2010
    Ferndale, Washington
    2,001
    There are 2 metal panels that go there. It is not air cooled without them, they divert the air. I have a pair, PM sent.
    Aug 2010
    2,001
    Anyone have a picture ? I can't find a picture of the bell housing/cooling shields. The parts book only shows a rough idea. Does anyone have a picture they could post?
    Dec 2005
    Ferndale, WA, USA.
    28,759
    This is the best I could do with that, the Shield is Picture Number: 0230-16
    It bolts to the same threaded 5/16" course holes in the Converter Housing as the Front Cover Plate.
    Speedster Member
    Mar 2013
    Melbourne Australia
    303
    Dave- I remember posting a similar thread a few years ago. Those parts are deflectors (Group 0230-16 & 19) to keep engine oil lost from the rear main seal and muck out of the inside of the Bellhousing. I can't locate it but I swear I have seen a Service Bulletin on these parts and their fitting procedure (nothing really special.). I took a couple of photos- The red oval indicates the angular part 1544243 that goes along the bottom of the Bellhousing. The Green oval shows the side shield, part 1544249, and note that it doesn't actually cover the hole.
    Apr 2012
    princeton mn
    3,055
    Looks like and easy build. Just a piece of tin with some holes in it.
    Aug 2010
    2,001
    58L J8 Guy- Parts are on the way.
  8. #8
    Speedster Member
    Oct 2013
    Butler, PA
    122
    Quote Originally Posted by (S) View Post
    Thank you, Dave
  9. #9
    Speedster Member
    Oct 2013
    Butler, PA
    122
    Thanks to all who have responded and commented.
    Dave
