Thread: Rear axle splines
    Oregon
    46
    Rear axle splines
    I have a 67 Avanti. What number of axle splines does it have?
    thanks in advance
    5,738
    Studebaker used 19 splines. The later Avantis used a finer spline, but not sure when they changed. You might pull one to be sure. It's good to do to repack the outer wheel bearings anyway.
    Devon, Alberta, Canada.
    382
    I believe flanged axles were 31 splines. My '63 has tapered axles and 19 splines. I think '67's were flanged. If you have a big nut holding the axle in you have tapered. No nut---flanged.
    Apr 2006
    Union Gap, Washington, USA.
    609
    You might as well put zerks in to make packing the outer bearings much easier too. Think I wrote up the procedure a deckade or more ago and posted it here.
    65 2dr sedan
    64 2dr sedan (Pinkie)
    61 V8 Tcab
    63 Tcab 20R powered
    55 Commander Wagon
    54 Champion Wagon
    46 Gibson Model A
    50 JD MC
    45 Agricat
    67 Triumph T100
    66 Bultaco Matadore
    Jan 2007
    waukesha, wisconsin, USA.
    419
    My 66 had tapered axles with 19 splines like Studebaker. Avanti used a HD Dana 44 with 30 spline axles around 1970 and up. 67 to 69 might have used the 65/66 Studebaker flanged axle rear end with 27 spline axles. The key is whether it has flanged or tapered axles. An early 67 might still be tapered.
    james r pepper
