Thread: 2R5 - Fuel gauge dilemma
    Dec 2017
    New Hampshire
    59
    Gentlemen,
    I have a 1951 2R5 pickup. Recently I had the fuel tank that I got from Ted Jensen (845-224-7934) completely reconditioned by Mark at Steve’s Classic Cars in Milford, Ohio (513-722-1758, 513-312-1880.) Ted's gas tank was a gem and it needed very little done to it to get it in A-1 condition again. Steve’s Classic Cars also replaced the float/ gas tank level sensor that fits inside the tank.
    I filled the tank up and the fuel gauge needle read 'left of empty.' The needle slowly started to rise and then it stopped at around 1/4 tank. Then the needle 'jumped' to about 1/2 tank, where it stopped again. Next the needle rose slowly and steadily; then it jumped to 7/8 full. The needle rose to 'right of full'; stayed there a while, then went all the way to empty again.
    My truck was sitting on flat ground and the fuel was not sloshing around. Also, the float/ gas tank level sensor is new and I'm certain it's the correct part for the tank. Can the fuel gauge needle be lubricated with WD40? Should I try that at all?
    Why is the fuel gauge needle 'jumping' rather than rising slowly and steadily as I thought it should?
    Where's the problem that I can't decipher and what's the fix?
    Thanks for your helpful replies.
    Mark in Ohio
    Oct 2010
    Dundee, Oregon
    3,171
    I would check for a bad ground.
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
    Dec 2017
    New Hampshire
    59
    Thanks Ed,
    We'll start there. I'm curious what other ideas the other guys might have.
    Mark in Ohio
    6,013
    Agree with Eddie. The intermittentcy strongly suggests bad ground.
    28,779
    Are you running 6 Volts Positive Ground or 12 Volts Negative Ground, and did you communicate that to the Tank Repair Co.?
    Dec 2017
    New Hampshire
    59
    I'm not sure what information I should communicate to them. Why does it matter whether it's a positive or negative ground system when restoring a gas tank Thanks for your reply. Now I'm curious.
    Mark in Ohio
    28,779
    Very simply, because THEY replaced the Sending Unit! How many OHM's was it?
Tags for this Thread
