Results 1 to 8 of 8
Thread: Shift rod adjusting gauge
    Commander Member ellagee's Avatar
    Nov 2009
    Quincy, MI, .
    90
    Looking for a transmission shift rod adjusting gauge J-1308. Or does anyone have another way to adjust the shift rods?
    Apr 2005
    California
    4,875
    On some models you can take an Allen wrench of the appropriate size and slide it into the holes to lock the shifter in neutral position.
    60V-L6 - 60 Lark convertible
    President Member (S)'s Avatar
    Aug 2010
    Ferndale, Washington
    2,007
    I always use a 'helper' and have them shift the car while I inspect how all of the rods are moving. I look for sloppy 'Swivels' , missing washers, wave washers, wear in the arms, etc. Then start with one end and replace as necessary. I stock most of the swivels, rods and hardware, so having them ready also helps. You can ID what you need, before you take it apart. Adjustments come right back, or close to where they should be. Adjust until they all look good and work good. What vehicle/transmission are you working on?
    Commander Member
    Jul 2015
    Tempe, AZ
    67
    Quote Originally Posted by RadioRoy View Post
    Yep, I use a 5mm on my 52.
    3H-C5 "The Blue Goose"
    Apr 2005
    mass
    3,771
    I don't believe there is an aligning hole for the truck shift rod swivel box...is there ?? I just installed a replacement T86 in my 2R6 and am wondering if the shift rods will need adjustment, and /or the clutch pedal ???
    Speedster Member
    Jun 2007
    Michigan
    167
    I made a copy of the J-1308 tool. I could make some more if the demand is there.
    JT
    Silver Hawk Member
    Sep 2005
    Washington, DC, USA.
    6,013
    Quote Originally Posted by jackb View Post
    Yes, it's done by removing the little round plug/cover in the lower shift lever bracket. I ground down a piece of square wooden dowel to insert in that box to hold the levers in place.
  8. #8
    Nov 2009
    Quincy, MI, .
    90
    I recently came across an original J-1308 transmission shift rod adjusting tool. I had a machinist friend make up a couple and have them for sale for $30 dollars each plus shipping. This just lets me recover my cost.
    See attached picture. The original is on the left and reproduction on the right.
