Thread: vent window and door window ( removal ) on 56 57 58 commanders
    Sep 2016
    Bay Area
    94
    Hello friends---- I need to replace a door window---- when doing so, does the vent window have to come out
    or be moved at all......if vent has to come out--- does that action necessitate new vent rubber ?
    thanks all------
    714
    Do all possible to save rubber. No new weatherstrip fits and if you replace it you might never get the window closed again.
    4,875
    The shop manual should explain the process.
    Sep 2016
    Bay Area
    94
    Jeffry---- which rubber----there door rubber - which I did buy
    there is the fuzzy window channeling
    the last the vent window rubber
    which "rubber " are you referring to ?
    714
    The rubber around the vent window (ventilator). The U-channel will be OK I get it from Restoration Supply. Replacing that really decreases rattles.
