Results 1 to 9 of 9
Thread: Is this a Correct Gas Cap for a 1950 Land Cruiser
    My other Studebakers have 2 grip knobs on the caps. The only time I've seen a plain round cap, and also the only time I've seen a painted gas cap, is when it's an external cap such as used on pickups with the tank behind the seat. The black paint does match the rest of the car however, but does anyone know if this is correct for a 1950 Land Cruiser?
    28,752
    Post
    It very likely IS a Vented Cap and quite usable on a 1950, but we could tell better if it will fit and seal properly with a bottom view of the Cogs that secure it and the Gasket surface.
    These Round ones are an OK replacement for the OEM kind with 2 Little "handles", but this one is VERY old having that recessed center, and may have a deteriorated Gasket.
    Montpelier, VT, USA.
    1,160
    Here are a couple photos of an NOS cap, part number 523821(I hope that's correct as this is obviously non-vented).
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    I guess I now know where my gas cap came from. Just saw this on ebay.
    I know Studebaker owned Eaton, and Eaton and Stant made gas caps.
    I wonder who made the gas caps for Studebaker?
    https://www.ebay.com/itm/Stant-BG-23...tEn:rk:56:pf:0
    Oct 2005
    St. Louis, Mo.
    1,629
    As the 1950 gas tank has no other vents I would always make sure the tank gas cap is vented
    Quote Originally Posted by unclemiltie View Post
    Yes, for sure. That's why I wonder why Dan's cap pictured above has the correct part number for 1950, but it says "NOT VENTED". A person has to be careful buying off ebay, as many of the listed caps also are non vented.
    I just checked both my 50 Champion and Land Cruiser, and they both have vented anti surge caps.
    Here are the pictures of my Champion and Land Cruiser caps. For some reason I couldn't get them to post on my last reply.
    President Member Bullet's Avatar
    Thousand Oaks, CA, USA.
    1,477
    Can a nonvented gas cap be drilled to be vented? Just curious.
    Mark
    4,872
    Quote Originally Posted by Bullet View Post
    Mark
    Usually does not have to be drilled. A pair of pliers can remove the seal and then the cap will be vented. The non-vented caps that I have seen had an additional center seal. Removing that left the original outer seal and made the cap vented.
    There was a big discussion at a Nash show 40 years ago when someone's car would not run because it had a non-vented cap on it. Everyone was coming up with the most ridiculous ideas, drilling the filler tube and basically modifying the expensive non-removable part, while keeping the inexpensive removable part. I took one look at the cap and fixed it with a pair of pliers. It's amazing to me how some folks think, or fail to think, that is. Maybe I have been blessed with a mechanical mind.
