Results 1 to 6 of 6
Thread: Rebuild kit
    Jan 2011
    38
    Rebuild kit
    I need a complete rebuild for a DG 200 transmission that goes in my 1951 Starlight coupe with a 232 V8 engine. Where can I purchase the parts? Also will a automatic drive from a 1952 6 cyclinder engine fit a V8?
    6,001
    Try Jerry Kurtz. jerezstude on this forum.
    2,796
    Look at the tags.
    There were three series DG 150 ,DG200 and DG250 with some variations.
    More than likely the one from the 6 cylinder is a DG150 which is lighter duty.
    http://www.curbsideclassic.com/autom...-so-in-others/
    Jerry Kurtz is the expert on these.
    717 266 0509
    http://www.studebaker-info.org/text3/1stgearst.txt
    Oct 2010
    Dundee, Oregon
    3,165
    I got a good rebuild kit for my DG250M from Northwest Transmission in Ohio. Reasonably priced and very complete. You can find them online.
    http://www.nwtparts.com/
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
    14,141
    As Mr. Kapteyn indicated, the 6 cylinder used the light duty DG150; not possible nor desirable behind the 232 V-8.
    Rebuild kits are also available from FATSCO. https://www.fatsco.net/3-band-borg-warner.html
    711
    Had DG 150 overhauled not long ago and Studebaker International had everything needed.
