It is commonly accepted that it is necessary to dial indicate non-factory engine/bellhousing pairings to insure proper alignment. I am posting this to alert our membership to dial indicate ALL pairings, even if it is factory original. I have measured and aligned numerous bellhousings. Some factory installations are misaligned as bad as a random selection. The pattern I have recognized is that quite often, the rear bellhousing flange on the block is out of square (90°) to the crankshaft centerline. Every error I have found is the top of the flange surface is leaning toward the front of the engine. The ones I have measured have always been accurate side to side. Shimming the bellhousing so the face is perpendicular to the crank usually brings the bore in alignment as well. Evidently Studebaker had an error in their fixturing used for machining the blocks and it was never corrected. Assembly just did the best they could and lived with the error. The most recent example I just worked on was a 259 which was out .012" from the base of the flange (crank centerline) to the top. I have found several others that were out .020". If you project this measured error to a theoretical full circle, the total indicator reading error would be .040 for a .020 measured error. If the engine is to be rebuilt, check this feature and have the machine shop correct it if possible. If the engine is together, your only option is to shim the bellhousing. I add enough shim at the top to establish face alignment. I snug the bellhousing using 3 bolts (the two at the bottom and one in the center at the top with the shim). You then measure the gap at the other bolt hole locations and make appropriate shims for those locations. I buy shim stock assortments from McMaster Carr (.001,.002, .003, .005, and .010 increments). It is easily cut with a snips or scissors and punched with a hole punch on a block of hardwood.
One last note, when checking face runout, always put some light thrust pressure on the crankshaft so it does not float back and forth giving an inaccurate reading.
Jim
Jim
