Results 1 to 4 of 4
Thread: 1957 grill
    Champion Member
    May 2012
    Morganton, NC
    4
    1957 grill
    I have a 57 1/2 ton pickup with the fiberglass grill that keeps cracking. Would it be possible to replace this grill with a metal one from a different year? If so what year would fit with the least modification? Thanks
    Silver Hawk Member
    Jun 2006
    Spokane, WA, USA.
    8,107
    While I've not done the retrofit, the '54-56 would be the most likely to fit with the fewest modifications. Make sure to get the headlight bezels and parking light lenses, as they're unobtainum.
    Dec 2005
    Ferndale, WA, USA.
    28,368
    I would find out WHY the cracking is happening, I have had my 1 Ton Dually Transtar since 1989, and had no cracking with a much harder riding Truck then a 1/2 Ton with no problems.
    If the Radiator Support and Cab Mounts are incorrect, Frame outriggers rusted out, Frame cracked etc. that would be why.
    Unless you regularly follow too close behind Rock Trucks, I don't know what else would cause that!
    Silver Hawk Member
    Sep 2005
    Washington, DC, USA.
    5,896
    Quote Originally Posted by PackardV8 View Post
    What Jack said. However, the 2R-series 49-53 grilles are much easier to find and will be relatively inexpensive -- BUT they only cover the area between the front fenders and would leave the mounting holes on the front of the fenders exposed.
    Here are a couple:
    https://tinyurl.com/ycz69cek
