Results 1 to 24 of 24
Thread: Dual Master Cyl on mid 50's Studebaker
    Sep 2016
    Bay Area
    77
    Folks---- a few ?'s
    Is a Dual master far better than SINGLE master, IF IF , a future front disc brake conversion is planned ? Does the TURNER brake frame mount dual master have enough "PUSH" with the foot to actuate the full hydraulic pressure needed for good stopping?
    Lastly, is my old single master cyl just fine enough for disc brakes ? THANK U ALL
    Douglasville, Georgia, USA.
    3,345
    Quote Originally Posted by 63looks59 View Post
    Folks---- a few ?'s
    Is safety a concern to you?
    With the single action master cylinder, if a brake line gives way you have NO brakes.
    With a dual master cylinder, if a brake line gives way, you still have 2 wheel brakes that will still be in service.
    Jul 2015
    Tempe, AZ
    65
    I did a Turner dual master and disc brake conversion on my 52, along with all new hard lines and complete system rebuild. It's got great pedal feel and I can lock them, so plenty of power.
    3H-C5 "The Blue Goose"
    Jan 2005
    Yakima, Wa, .
    1,531
    Quote Originally Posted by gjamesk View Post
    I did the same install on the Lark, with an eye for future disc brake upgrade (only have a few hundred miles on rebuilt drum brakes).
    Middle Tennessee
    1,541
    YES, worth every penny....
    I nearly lost my 2R5 about 2 blocks from the SNM due to a blown rear wheel cyl that had been sleeved and failed. Single pot MC lost all it's fluid in a couple pushes. went straight thru a stop light with no emergency brake, as the rear linings were coated with DOT 3.
    DID YOU KNOW YOU CAN DRIFT A STUDEBAKER?
    Fort Pierre, SD, .
    980
    What master cylinder is that?
    Sep 2016
    Bay Area
    77
    Is a Dual master cyl Required For front disc brake conversion OR can the single master function fine for front disc ????
    1,594
    A single will function.................Now, define "fine". There's a big safety reason for dual master cylinders. The dual MC cost is about the same as a single and the re-plumbing is pretty simple and not expensive. To be even better, replace all the steel and rubber lines. Even the newest Studebaker brake lines are over 50 years old and have been corroding on the insides and rusting on the outsides all that time.
    The safest way to brake is to drive as though the car might loose the brakes the next time you step on the pedal. Don't drive to the limit, like so many of today's fools on the road do. I've had modern dual master cylinder cars loose brakes on one side, and the pedal goes almost to the floor and scares the crap out of a person. I like my cars original, so I stick with the single master, but make sure the whole brake system is in good shape, and I always switch to DOT 5 silicone on my older cars.
    Fort Pierre, SD, .
    980
    What I am asking is what is the brand and part number or application of the master cylinder that is pictured.
    Gainesville, FL
    14,763
    That's the "Corvette style", available from most big hot rod stores and countless websites.
    I purchased this one for my '51: https://www.speedwaymotors.com/Unive...Bore,4316.html
    I also bought a remote reservoir setup for it. I'll be installing it this weekend, I'll let you know how it works out.
    21,188
    Quote Originally Posted by mbstude View Post
    I am a believer in split braking systems. This one that Matt posted looks good and is even less cost than a new replacement single system cylinder (I remember when they were $9.95.).
    Middle Tennessee
    1,541
    After the scare I had, i believe in Dual Pot MC's. Did you know that the emergency brake won't work if you coat the rear linings with fluid?
    10,359
    Here again, is the often overlooked judging rule regarding not penalizing owners for items changed for safety reasons. And I can't think of anything more important than brakes for safety! Even the Amish have taken to adding hydraulic brakes to their buggies. I have not installed dual master cylinders to any of my vintage cars, but I know I should.
    Reflecting back, I recall 1964, my first car, was a 1955 four-door hardtop Buick Special. We had some relatives come to visit us who lived on the coast. Up until that time, I don't think they had ever been over a hundred and fifty miles inland! At our home on the N.C./S.C. state line, (near Shelby, N.C.) they were in awe of our rolling hills, and already acting as if they were in the mountains. We overloaded two cars, my 1955 Buick, and our 1953 Pontiac family sedan, and headed to the Blue Ridge Parkway! Me, a very inexperienced driver, and that old Pontiac with my Dad leading the way.
    Back then, it was a great adventure. Zero cars with dual master cylinders. Our flatlander relatives might as well been on the moon. We had a terrific time, but in retrospect, it was really a dangerous excursion. My dad had schooled me on brake stabbing/checking rather than brake riding, and I listened. On that trip, we smelled lots of overheated brakes from others and a common site was people pulled over so their overheated brakes could cool.
    Yesterday, I rode my motorcycle 165 miles on some of those mountain roads. Completely different era, and technology. Even the bike has ABS brakes. Probably all of us with the ability to do the work should summon up the energy to do the dual master upgrade on any of our cars we plan to use in public.
    Feb 2012
    lafayette in
    4,444
    I lost the brakes on my 51 Caddy hearse (6000#) once. Luckily I was approaching a light and had slowed down. I grabbed the E brake and got it stopped but have converted a half dozen older cars since then to dual circuit masters. You'd be sunk if it happened in the mountains.
    Apr 2011
    Omaha NE or Soldier IA
    834
    Is that Speedway master cylinder a direct bolt on to the frame or not?
    Apr 2011
    834
    Never mind... What I thought were mounting holes are actually the outlet holes. So does Speedway have a mounting kit hidden somewhere in their site?
    Apr 2017
    210
    You should call up Turner and ask them all the questions. They are very helpful.
    Gainesville, FL
    14,763
    As far as I know, Jim Turner is the only source for an under the floor dual MC bracket for Studebakers.
    President Member rusty65's Avatar
    Catonsville, (Baltimore County) MD USA
    845
    I am debating having a dual master cylinder put in my '60 Lark,knowing that I want the entire brake system redone anyway as a matter of safety.I will probably stay with the drum brake system, but the dual master cylinder sounds like a hit.Thanks for starting this thread, it's got me thinking....
    700
    When did they switch to self actuating brakes?? I think a Turner conversion is a good idea but I have never had a Studebaker MC fail I am knocking on wood and crossing fingers as I type! Of course you can drift a Studebaker! Did it all the time with my 61 Hawk: problem was in a 4 wheel drift to the left the WCFB carb would starve the engine of fuel and it would cut out.
    4,814
    1954 was the first year for self actuating brakes on a Studebaker car.
    Great Falls VA
    3,386
    ..... for self actuating brakes ..
    you mean "Self-Adjusting"?
    64 GT Hawk (K7)
    1970 Avanti (R3)
    700
    No. Older brakes used wc to push the shoe into the drum. The more you push the more you brake. Trouble was you had to push really, really hard.so a puny person in an emergency goes crash. Engineers - apparantly in or about 1953-- came up with a slick trick. . Selfactuating or selfenergizing brakes. They use the wc to push the shoes too but then using mechanical advantage or magic the primary actuates the secondary which then does most of the braking. That is why they are different--the secondary often has more lining than the primary. That is why the secondary often shows more wear. And the car stops way better with far less pedal pressure--a quantum leap forward in automotive safety.
