Results 1 to 16 of 16
Thread: 63 GT front end rebuild
    Feb 2018
    Mansfield Texas
    36
    Looking for advise on what to buy
    A local suspension shop in business since 1928 & local members have used closes at the end of October
    I called to get in before he's gone forever and can get an appointment in 2 weeks. The owner said he won't order parts but would install whatever I bring him. At first I though the entire SI front suspension kit at $1300 was the way to go. I don't want to waste money on parts I don't need. What would you buy?
    There is slight but not excessive king pin play. The car tracks straight but has play in the steering wheel
    I was thinking all rubber bushings in upper & lower A arms. What about metal bushings?
    I have to order soon to have parts in time.
    All advise appreciated.
    3,720
    order everything available
    let thee shop decide what parts are not good. Return what is not needed. jimmijim
    Feb 2018
    Mansfield Texas
    36
    Found part of my problem
    Whatever these wheels are - they're wrong
    Sway bar has ground down the inner threads to the cords.
    3,720
    Your wheels are so wrong. May be for a front wheel drive car. jimmijim
    Jul 2018
    Australia
    20
    My goodness how did you ever turn right or left ? Cheers
    Feb 2011
    Pasadena, Ca
    870
    The sway bar is not touching the tread face. I'll bet the camber is way negative and/or the car has toe-out to scrub that edge off like that.
    4,796
    I agree. By looking at the wear and no feathered edge, I'd say the camber is way off.
    Apr 2006
    St. Louis, MO, .
    1,942
    ...have you looked to see if the outer tie rod ends are also rubbing??
    Feb 2018
    Mansfield Texas
    36
    Outer tie rods are clear
    Apr 2006
    St. Louis, MO, .
    1,942
    Well that's a good thing!
    Feb 2018
    Mansfield Texas
    36
    After all was said & done, I had A arm bushings, king pins, sway arm bushings & new coil springs installed
    i saw the old A arm bushings that were so worn, the side of the metal sleeve holding the rubber was worn through.
    the previous owner said I needed a new steering box but all the slop came from the worn out parts not the steering box. It tracks straight & no play in the wheel.
    on a bittersweet note, my car was the last one to pass through this shop’s doors after 90 years of operations.
    My car is in the background on a news feature of this location
    https://www.wfaa.com/article/news/lo.../287-608361130
    Great Falls VA
    3,389
    The (((ad))) leading to the clip is SIX minutes ..... l o n g .....
    64 GT Hawk (K7)
    1970 Avanti (R3)
    Feb 2018
    Mansfield Texas
    36
    Sorry, I don't own the TV station
    Austin, Texas
    962
    Quote Originally Posted by Chartrain View Post
    Good spring shops are getting hard to find. Down here in Austin there's no such thing as building springs from scratch...
    President Member raoul5788's Avatar
    May 2008
    Cheshire, CT 06410
    2,121
    The ad didn't run for me. BTW, was that jack stand on the rocker panel or the frame? I hope the latter!
    Chip
    '63 Cruiser
    '57 Packard wagon
    '61 Lark Regal 4 dr wagon
    '50 Commander 4 dr sedan
    3,720
    Quote Originally Posted by spokejr View Post
    Wheels have too much backspacing.
