Results 1 to 12 of 12
Thread: FoMoCo Gasket
    Jan 2011
    1,841
    FoMoCo Gasket
    I can not remember the exact model, but the FoMoCo exhaust manifold flange gasket is better than the standard Studebaker variety as it has some asbestos as part of the composition, as opposed to a straight metal gasket.
    Anyone know what model Ford gasket I need for an Avanti?
    Thanks in advance for the assistance.
    Great Falls VA
    3,386
    Notes from years ago...
    EXFLG - Exhaust flange gasket - NAPA# F5436AK ( califdrming@juno.com) 60 - 62 Ford small 6,
    57 - 67 Cadillac a Victor F5360-C. jtusher@home.com
    Asbestos exhaust manifold gaskets 62-64 Ford small sixes / 57-67 Cadillac
    64 GT Hawk (K7)
    1970 Avanti (R3)
    28,615
    They are for the Falcon 1960-1964, 170 and 200 6 Cyl. Ford engines.
    Jan 2011
    1,841
    Thank you all this is just what I need, sadly for some reason the pass side gasket only lasts 4 years:-(
    4,816
    Quote Originally Posted by Hawklover View Post
    Is it possible that the passenger side manifold is slightly warped on the gasket surface?
    Or, is it possible that the exhaust pipe frame mount is putting too much pressure on the manifold?
    President Member WinM1895's Avatar
    Nov 2013
    Simi Valley CA
    866
    C1DZ-9450-A (replaced C0DZ-9450-A) .. Exhaust Manifold Gasket to Inlet Pipe / Obsolete
    1960/62 Falcon/Comet 144/170 I-6 // 1963 and later is different, no 200's until 1964.
    GREEN SALES CO. in Cincinnati OH has 89 = 800-543-4959.
    Jan 2011
    1,841
    Roy the only thing I did some years ago was eliminate the heat riser valve, and in its place put in a spacer. The pipes are all SS from Don Simmons.
    - - - Updated - - -
    Thank you for this, I have been a customer of Green for years for my big Fords!
    Quote Originally Posted by WinM1895 View Post
    Nov 2013
    Simi Valley CA
    866
    -Thank you for this, I have been a customer of Green for years for my big Fords!
    I've been dealing with Green Sales since the late 1960's and have typed parts references for them on a daily basis since 11/2006 on ford-trucks.com
    Jan 2011
    1,841
    LOL.........I also bleed Ford blue:-)
    Marysville, Washington, USA.
    552
    FelPro 60052, easy as that. Lou Cote
    Jan 2011
    1,841
    Many thanks Lou!
    Quote Originally Posted by dynolou2 View Post
    Jan 2011
    1,841
    So after a small time on the lift, I found that the passenger side gaskets were very thin, replaced them, just for the H of it checked the drivers side......felt a leak......removed it and found that the gasket was actually burned in half.....and this the better asbestos variety.....had to utilize two gaskets on the drivers side, I suspect that the exhaust manifold is slightly warped, the double gasket sees to have done the trick as the leak has been stopped.
