Results 1 to 9 of 9
Thread: Taping Sheetrock, method preferred ?
    Dec 2007
    Union, CT., USA.
    4,433
    Any One have a preference as to what tape works best, paper or self stick mesh
    Joseph R. Zeiger
    Oct 2004
    18,018
    (opinion)
    I like the mesh tape.
    Get a GOOD set of blades (3 or 4 widths), and a GOOD corner tool.
    Buy the light weight pre mixed mud.
    Good mesh sanding block/pads.
    Spend countless hours mudding and taping and sanding and sponging and mudding and taping.
    Then, price it and see how cheap some will do it.
    Stay away from spatter coats, and knock down finishes.
    President Member Colgate Studebaker's Avatar
    Jan 2009
    Citrus Springs Florida
    975
    My wife and I have physically built two of our homes, and I've done lots of drywalling. I also prefer the mesh tape and like Jeff mud, sand, mud, sand. Bill
    President Member t walgamuth's Avatar
    Feb 2012
    lafayette in
    4,472
    Its one of the last things in a house I would do myself (in the past). I have done a bit. It takes me 10 times as long as a skilled person and my work is 1/10th as good as theirs....but put some paint on and enjoy and it won't look too bad after a couple of beers!
    President Member garyash's Avatar
    Oct 2004
    Dartmouth, MA, USA.
    1,829
    I like the mesh better than paper tape. Using real plaster that you mix with water makes the best first coat, just put it on thinly so you don’t have to sand much. After that, the other coats can be pre-mixed mud. Be patient for the mud to dry thoroughly. To cut down on plaster sanding dust, get one of those attachments for a shop vac that has a bucket that you half-fill with water and an attached sanding head that uses abrasive mesh.
    Gary Ash
    Dartmouth, Mass.
    '48 M5
    '65 Wagonaire Commander
    '63 Wagonaire Standard
    Dec 2008
    Greer, sc, USA.
    10,401
    Quote Originally Posted by 63t-cab View Post
    Some good suggestions, BUT...are you asking regarding a small repair/patch...or are we talking about a big full panel project???
    I have used mesh repair kits, but if I were faced with a large project, I would hire a professional and keep time available for the stuff I'm good at (like operating a recliner & TV remote).
    [IMG][/IMG]
    Jul 2010
    Above the Equator
    1,909
    My tribulations with the self stick tape is it doesn't always stay stuck. Also, I've had my DW blade snag on the mesh and create problems. That is not a vote for paper, just experience. Otherwise I agree, mud, sand (repeat as often as necessary). I'm usually at about 5 processes before I'm done but I am going for smooth walls, not spatter coating. And while I realize the spatter has some architectural function most old DW guys have told me it is mostly to cover up imperfection to get the job done cheaper/faster.
    What I really hate about drywall is hanging corner bead!!! One other thing, (just my opinion) if you opt to use the rounded bead (not a bad idea with kids or elderly around) it looks pretty lame if used on the bottom of a window. My personal preference is straight on the horizontals and round on the verticals.
  8. #8
    Speedster Member Pancho's Avatar
    Sep 2012
    Pasadena, CA
    199
    Mesh is my preference. Unless you do this all the time the paper can cause little problems. Air bubbles behind the tape is the most problematic. Usually you find them the next day. The guys I hire use paper but they’ve got decades of experience. My 2 cents.
  9. #9
    President Member raoul5788's Avatar
    May 2008
    Cheshire, CT 06410
    2,121
    Mesh on the flat, paper in the corners.
    Chip
    '63 Cruiser
    '57 Packard wagon
    '61 Lark Regal 4 dr wagon
    '50 Commander 4 dr sedan
