Engine ID help.
It would be Number: 14,644 289 ("P")
The South Bend assembled 1963 289 Engines started at 93,601 so it is too LOW!
The Los Angeles assembled '56 President 289's started at: PL2701
OPPS, Wait a minute! That MUST be a poorly stamped "L" making it PL4,644, the Turquoise Paint also matches a 1956 President Engine!
If it has a Bi-pass Oil filter or None, without the Full Flow Oil Filter at the Lower, Right Rear, that is definitely a 1956 289.
Also the Casting Number at the Right Front side of the Car & Block, would be a SIX Digit 5XXXXX Number not a Seven Digit 15XXXXX.Last edited by StudeRich; 08-11-2018, 05:09 PM.StudeRich
Perhaps it is a replacement block not stamped at the factory and they used a 1 instead of an I.
EDIT: I agree that things like the location of an oil filter would separate the 1956 from the 1963.Gary L.
This is a photo of the engine, it has 289 decals on the rocker covers but I wasn’t sure it really was. Anyone can apply a decal and call it what they want.
Mike Kelly
Regional Manager
Texas
1963 Lark Cruiser
1962 GT Hawk
1965 Commander 2dr v8 auto
Originally posted by StudeRich View PostYeah BUT, if it is a "1", The Serial is TOO Low to be a 1963!
Without the Decimal Dude's Help, I THINK that is correct!Gary L.
It does have the Bi-pass, drop-in Cartridge Fram Type Oil Filter on top, so if there is none on the bottom, clearly a 1956.
I would guess that the Truck is probably a 6E5 6 Cylinder Truck, but COULD be a 6E7 with just another V8 replacement.StudeRich
So it’s my understanding that even though it’s being represented as a 289, and by motor number it is actually a 259. Am I correct?Mike Kelly
Regional Manager
Texas
1963 Lark Cruiser
1962 GT Hawk
Originally posted by Mrkelly View PostSo it’s my understanding that even though it’s being represented as a 289, and by motor number it is actually a 259. Am I correct?Gary L.
Originally posted by StudeRich View PostIt does have the Bi-pass, drop-in Cartridge Fram Type Oil Filter on top, so if there is none on the bottom, clearly a 1956.
EDIT: 1956 President engines start at 22,001 and this engine appears to me to be 14,644.Last edited by studegary; 08-11-2018, 06:53 PM.Gary L.
