Results 1 to 24 of 24
Thread: OHV 6 Weak Spots
    Commander Member
    Jun 2018
    Southern Maine
    30
    OHV 6 Weak Spots
    I'm pretty familiar with the 259/289, but not so much with the 170 OHV 6. What should I expect for issues and/or what do I look for when evaluating a vehicle for purchase with one of these? I'm on the hunt.
    Thanks everybody in advance - this is a fabulous site, oozing with knowledge! Tim
    Oct 2004
    17,967
    Here's some info....
    http://www.studebaker-info.org/text3/ohvsix.txt
    (copy)
    MArch 2004 -
    Studebaker Overhead valve Six cyinder engine -
    Its not a great engine, being a conversion of the flathead done in a
    hurry it seems without sufficient pre production testing.
    But the head cracks can be welded.
    I have three OHV 6's and havent had any problems with the heads cracking.
    I have had lots of exposure to the OHV six. First off, the engine is
    not that much different from the '59-'60 flathead from the deck down.
    Items such as the pistons, crankshaft and rods are virtually
    identical. The heads were prone to crack and Studebaker knew this.
    Subtle changes were made in the area between the valves, which is the
    area most prone to show cracks first. Typically burned valves were
    also an issue, caused by carbon flaking off in the combustion chamber,
    caused by excessive oil consumption. This carbon would get between
    the valve face and seat, which would start the whole process. There
    are other weak links in this engine, other than just cracked heads.
    Carburation was always an issue, with both the AS and RBS carburetors.
    They tended to run rich and load up, especially when cold. The heat
    transfer tube for the choke, inside the exhaust manifold tended to
    crack in one of the dimples, allowing exhaust to enter the choke
    stove. Pistons were changed in '63 which included a longer skirt to
    reduce piston slap. These skirted pistons tended to develop cracks in
    the corner radius of the skirt. If the skirts broke off, the piston
    cocked in the bore, cracking the cylinder. I have seen two that
    failed in that manner.
    The '59-'62 pistons without the skirt are generally the better way to
    go during an overhaul on a '63 or '64. The piston slap issue was of
    more concern beginning in '59 when the wrist pin bore was positioned
    lower than the '58 and prior Champion sixes. The pistons lost some of
    their stability in the bore as a result.
    The oil drain-back holes in the pistons tended to get plugged with
    carbon, leading to excessive oil consumption early on. The '64 used a
    set of piston rings unique to that year. The '39-'63 used the same
    ones.
    According to DD's Studebaker six book, the later heads were worse
    because the engineers added more metal where there was too much already.
    At one time someone had written a complete article about the OHV 6
    cylinder heads, in Turning Wheels. (Perhaps someone with an index can
    look it up.) As I recall he mentioned Studebaker had added more metal
    in the area between the valves, and in the writer's opinion it made
    matters worse. I had heard a story at one time that mentioned the
    U.S. Goverment stopped using the Zip-Vans earlier than originally
    anticipated, due to the short supply of replacement cylinder heads.
    I had owned twelve different cars with these OHV sixes and all had
    similar problems. I do recall the heater hose came out in a different
    spot on the '64 head. Perhaps it came off of the front, and the rest
    off of the rear.
    As far as being slow, they were much quicker than the flathead they
    replaced. Had it not been for the inherent problems, I had always
    felt they had more than adequate power. Compared to a '59 with
    flathead six and automatic, an OHV with automatic was a rocket in
    comparison. At Bonneville they ran one for days on end at around 100
    MPH. I believe Paula Murphy was the principle driver of the six
    cylinder Commander. This was during the Granatelli speed trials.
    I have never owned a car with the ohv 6, but I have a friend who has one that
    he has driven for years. The car will cruise down the interstate at 70mph with
    no problem and has adequate pep around town. The only thing the owner of the
    convertible for sale seems to have right however is that the engine does not
    need to be lugged at all. These engines do have a bad reputation and it is
    mostly deserved, but taken care of, driven with care, they can last for a long
    time.
    I have had just as many with cracked heads on automatics, as I did on
    sticks, three on each. This idea of it being lugged will crack heads
    is bull. You cannot effectively lug an automatic. Poor coolant
    maintenance, low coolant level, deposits from hard water and burned
    valves will crack a head before anything else. From my experience the
    OHV 170 will need work when they get into the 50 to 80K range.
    Usually rings for sure, and sometimes valve work. I have never had
    any problems with the lower end. Many times the ring lands of the
    piston get worn and will be out of tolerance at about the same time.
    The cylinder bores never wore all that much and would take at least
    one fresh ring job. KK
    Dec 2005
    Ferndale, WA, USA.
    28,497
    Regarding the longevity of these OHV Sixes, there is an amazing gap between Love and Dislike!
    I never trusted them because of all the horror stories of cracked heads, that is until I owned this current '63 Lark Regal 2 Door Sedan that someone overhauled or rebuilt before I owned it. It came from Grants Pass, OR and I know nothing about it's history.
    What I do know is; this thing is strong and as durable as it gets! Runs like a Gazelle!
    This one was a direct manual 3 Speed and now is a T-96 Overdrive with the original Twin Traction Model 27, 3.73 Ratio rear axle.
    We may never know why some fail and others run forever, maybe the Cooling Jackets are badly cast or something on some, I do not know.
    One thing that may help with the Head cracking, is most nowadays when a Valve Job is done, get Hard Unleaded Valve Seats.
    Apr 2006
    St. Louis, MO, .
    1,942
    Rich, I too have no frills 2 dr OHV 6 Lark std with 3.73; mine a '62.
    I have an OD transmissions for it and wondered how the 3.73 be with OD.
    OK in your experience?
    Dec 2005
    Ferndale, WA, USA.
    28,497
    Better than OK! Cruises just fine at 65-70 on the Interstate and also gets going plenty quick enough for me, haven't been run over by a Prius yet.
    Sorry I do not have a Tach, but the Rear Axle Parts Websites like "Randy's Ring and Pinion" have: Speed, Tire size, Trans. Type, and Axle Ratio, to RPM Calculators.
    The O.D. made a whole New Car out of it!
    I never understood why a Dealer or Buyer would want to save $1-200.00 by not ordering a O.D. it would pay for itself in a couple months today, but of course at .25 cents a gallon, not so much!
    But the less noise level, Oil saving, engine wear, overheating etc. would make it worth it in the longer run.
    Silver Hawk Member
    Dec 2006
    Sacramento, CA, USA.
    5,160
    I've never kept an OHV 6 any longer than it takes to swap in a 259. The 259 will double the horsepower, give tremendously more enjoyment on the highway. (have you ever tried staying up with traffic in a OHV 6 while driving uphill for any extended time? No thanks.) The 259 will offer very similar gas mileage when kept stock and with proper gearing and OD, will cruise better, faster and more economically than the OHV 6.
    I can't think of any reason to keep one in a car. It was a stop gap effort to upgrade the flat head, and never should have been put in these cars. By the 60s, traffic was moving much faster than the 50s. Freeways were being built at alarming speed, which made all traffic move much faster and the underpowered cars were falling by the wayside.
    I won't own a car with an OHV 6, plain and simple.
    sals54
    Apr 2005
    California
    4,797
    Probably because they didn't understand what the overdrive does and all the benefits it provides. Old car people today still cannot fathom what the overdrive is or does. Amazing.
    60V-L6 - 60 Lark convertible
  8. #8
    Apr 2016
    Westbrook, MN
    684
    Had one in a 64 truck (3/4 ton yet!) It was a dumb combination but can't complain about the little 6 at all.
  9. #9
    President Member 62champ's Avatar
    Dec 2004
    Kentucky Bluegrass
    3,009
    Quote Originally Posted by Jeffry Cassel View Post
    Hmmmm, not a very common truck - total of 57 were produced for domestic sales - will not see too many of them - for obvious reasons.
    IIRC, part of the problem with cracking heads were people lugging them in too high a gear and not letting them wind up in the gear below - or did I imagine that?
  10. #10
    Champion Member
    Mar 2014
    Minneapolis, Minnesota
    17
    My 64 has the OHV with an automatic transmission. At lower speeds in and about town its a real perky engine and joy to drive, but I notice when I reach 50 or 55 mph on a two lane that same engine seems like its starting to really wind up on the rpm. If perception is reality, how's my perception here? Any member feedback on highway driving with the automatic?
  11. #11
    Silver Hawk Member
    Jun 2006
    Spokane, WA, USA.
    8,144
    Quote Originally Posted by 64LarkLover View Post
    The OHV6 torque peak, the point of maximum efficiency, is 2,000 RPM. At a guess, not knowing for certain your rear gear and tire size, 50 -55 would probably be 2,500 RPM, or above the torque peak. The OHV6 Champion has a 4" stroke, so it does not enjoy high RPM. You're not hurting it by driving 60 - 65; it's just telling you it would rather not.
  12. #12
    Dec 2005
    Ferndale, WA, USA.
    28,497
    Most of these OHV Sixes were standard equipped with 3.73 Ratio Rear Axle Gears which explains their Perkyness, that was one of their major failure causes.
    Without Overdrive, that is too Low a gear for the Engine to survive equaling TOO many RPM's which at 65-70 will very quickly cause overheating and eventually a Cracked Head.
    Maybe someone with easy access to the RPM Calculator can figure out if a 3.54 Axle with a one to one Trans. would be as good as a 3.73 with O.D.
    President Member christophe's Avatar
    Feb 2010
    Nancy,Lorraine , France.
    1,250
    That's what I thought too. So, when I rebuilt my engine a few years ago, I got hardened seats.
    Well, I had to change the head this year as there was two leaks behind the seats.I don't know what happened for sure. Maybe the machinist goofed this one. But I didn't touch the seats on the new head, except for surfacing.
    To me the OHV6 is good engine. I only wish Studebaker had designed an alloy head for it.
    Nice day to all.
  14. #14
    Dec 2014
    Minneapolis
    4,801
    I only put 60 miles on my 63 Lark with a 6 stick and no overdrive, because I didn't like the high revs at 50 MPH.
  15. #15
    Apr 2005
    mass
    3,758
    Why roll the dice with so many negative (historically confirmed) issue with this engine ? If original and you live on back roads <50 mph...go for it. If you want to keep your sanity on the freeway.....
  16. #16
    Golden Hawk Member
    Jul 2005
    Gainesville, FL
    14,803
    Here's a photo that may help. The white oval is being used to highlight the specific weak points of the OHV 6.
    Okay, only kidding.
    If you're in the buying market and looking for a car to buy, spend the extra money for a V8. You'll be happy you did.
    BTW, a 3.73 with overdrive behind an OHV6 is only good if you live in a flat area. If you've got hills, better go for a 4.10.
  17. #17
    Aug 2007
    Douglasville, Georgia, USA.
    3,344
    Quote Originally Posted by mbstude View Post
    Matt, I'll not be clicking on any more of your post's unless I have an empty mouth. I just spewed coffee all over my laptop. THAT was FUNNY.
    Jerry Forrester
    Forrester's Chrome
  18. #18
    Silver Hawk Member
    Jun 2006
    Spokane, WA, USA.
    8,144
    The 3.73 becomes 2.61 in overdrive and that's too high for the Champion OHV6 to pull. In overdrive, most came with 4.10 or 4.56.
    You OHV6 fans might review the last couple of threads and come to a consensus. Some are blaming the cracked heads on lugging and not downshifting. Rich is blaming it on overrevving.
    I'm with Matt on this one; it was just a weak design. The 3" bore didn't allow enough room for overhead valves, so the engineers tried to twist them in there. With enough time and money, they could have made it work, but we know it didn't stay in production long enough for Studebaker to work out all the problems.
    The bottom end was designed in 1939, for a 2300# economy car on two-lane roads with average speeds of 40 MPH. To ask it to pull 3500# vehicles on interstates at 70 MPH may be overstressing it.
  19. #19
    President Member r1lark's Avatar
    Oct 2004
    Winston-Salem, NC, USA.
    4,217
    Blog Entries
    36
    Quote Originally Posted by PackardV8 View Post
    After a lot of thought and review of the service bulletin regarding rear axle ratio choice, I put a 4.27:1 ratio rear axle in my '64 Commander 4-door sedan with OHV 6 and overdrive. Quite quick around town, and still can run 70 mph easily on the interstate.
    BTW, the axle was a NOS one from Newman & Altman - pulled the rear cover to inspect (perfect inside) and installed.
    Last edited by r1lark; 08-26-2018 at 03:53 PM. Reason: added 'and overdrive' for clarity
    Paul
    Winston-Salem, NC
  20. #20
    President Member StudeNewby's Avatar
    Apr 2014
    Knightdale, NC
    965
    Quote Originally Posted by r1lark View Post
    After a lot of thought and review of the service bulletin regarding rear axle ratio choice, I put a 4.27:1 ratio rear axle in my '64 Commander 4-door sedan with OHV 6. Quite quick around town, and still can run 70 mph easily on the interstate.
    Just confirming, Paul, your transmission has OD, correct?
    Mike Davis
    Regional Manager, North Carolina
    1964 Champ 8E7-122 "Stuey"
  21. #21
    Oct 2004
    4,217
    Blog Entries
    36
    Quote Originally Posted by StudeNewby View Post
    Yes, thank you! It does have overdrive.
    Paul
    Winston-Salem, NC
  22. #22
    President Member Ron Dame's Avatar
    Feb 2006
    Asheville, NC
    1,575
    I've got over 100,000 miles on OHV6's. The original, still running well with unknown mileage before I put 65,000 on, is pickled for possible further use. It may have a bad cam lobe, but that's it. I've got 35,000 on an OHV6 with a 185 crank. I've not had head cracking or other issues with either. With a 4:27 rear and overdrive, I can cruise at 75 at ease.
    Now it is no powerhouse and sucks gas, and despite the improved torque with the 185 crank, I'd still rather have a worn 259. But I see no reason to ditch an OHV6 if it's running well.
    Ron Dame
    '63 Champ
  23. #23
    Apr 2005
    Lincoln, NE, USA.
    829
    My Lark with the OHV6 was a daily driver and I really couldn't tell you how many miles are on the rebuild circa 1985. It was dependable for in town driving and if I wanted to drive to Omaha I would take US 6 instead of the I80. I had more problems with the AS and RBS carbs while I was driving the Lark, the gas mileage was better with the AS but when gas was around a dollar something and I was only driving about 5 miles a day I could live with it.
    Jeff T.
    \"I\'m getting nowhere as fast as I can\"
    The Replacements.
  24. #24
    Speedster Member
    Jan 2007
    waukesha, wisconsin, USA.
    376
    A lot has been said about the OHV six. Every one I took apart with a cracked head had evidence of detonation. I am convinced that is the primary source of failure. If oil is kept out of the cylinders (valve guides and seals) and tuning is kept sharp, the engine will live a long happy life. The safety margin is slim. It will not tolerate neglect.
    james r pepper
