Results 1 to 18 of 18
Thread: flathead engine number
    Champion Member
    Apr 2018
    Maryland
    6
    I am looking at buying a 63 Champ, but it has a flathead six in it. Owner sent me the number 529278 and said it was stamped on top of the engine, I am assuming he means the head. I am in Maryland and the Truck is in Illinois, anyway of identifying the engine from the number he sent?
    May 2008
    Chatsworth, CA, USA.
    1,443
    If '63 is correct, it should be an overhead valve 6.
    Howard - Los Angeles chapter SDC
    '56 Golden Hawk (3 speed/overdrive - Running, but not yet driving)
    Champion Member
    Apr 2018
    Maryland
    6
    yes, that is what I was able to determine from the VIN, 170 OHC 6 with 3 speed with OD, the 3 speed with OD is still in the truck, trying to ID the source of the Stude flathead. From other sources it looks like the number he sent me may be a part number.
    Any pointers on where to look for an engine number...
    May 2009
    Moncton, New Brunswick, Canada.
    538
    On a flat-head 6-cylinder engine, the number should be stamped on the left side of the engine, at the front, just below the head. If you see the letter "I". that is actually the number "1". If, instead of a number, there is a clover leaf, then it is a replacement factory-built engine. Flat head engines were last installed in new vehicles in the 1960 model year.
    An embossed number on top of the engine is the casting number of the head.
    Bill Jarvis
    President Member Dwain G.'s Avatar
    Mar 2005
    Puget Sound, , USA.
    4,194
    Six cylinder heads are one of the rare instances where the casting number is also the part number. This head was used from 1950 through 1954. It was also a sub for the head that preceded it. That doesn't positively identify the engine though.
    Dec 2005
    Ferndale, WA, USA.
    28,387
    I would get the seller to photo the Serial Number Plate on the door latch Pillar or read it to you.
    The reason we are asking for more info, is that IF this is really a 5E-5 1960 Champ, it would have a 170 Flathead Six. A 6E, 7E or 8E 1961, '62 or '63/'64 could have the OHV Six.
    Champion Member
    Apr 2018
    Maryland
    6
    Thanks for the great info, I will get a photo of the serial number plate. Back story from the seller is he bought the truck from a person in Texas, and the flathead was in it when he bought the truck and thought it was original to the truck. will also ask for him to look for the engine number on the front of the engine.
  8. #8
    Apr 2006
    St. Louis, MO, .
    1,929
    Is this truck white?
    There was a Champ PU that color on EBay some years ago (in the Southwest I think?), that had a Commander flathead in it.
  9. #9
    Jan 2013
    british columbia
    1,160
    DSC08970.JPGDSC08971.JPGThe 529278 is the casting number and on the boss at the front left side is the engine number.
  10. #10
    Mar 2005
    Puget Sound, , USA.
    4,194
    Wish that engine number photo had been sharper, but it appears to start with a letter 'C' which would make it a 1952 Canadian car engine.
    I just realized the engine shown is not the engine in question.
  11. #11
    Dec 2005
    Ferndale, WA, USA.
    28,387
    It is a Canadian Champion Engine C41401.
    Everything in the background of the Pic is upside down, but the good news is the Block with a Head laying almost on it, is right side up!
    Yes it is only an example.
    Champion Member
    Apr 2018
    Maryland
    6
    no news from the seller, don't know if it was ever white, this is the truck. http://forum.studebakerdriversclub.c...56#post1086456
    Any down side to the flathead?
  13. #13
    Dec 2005
    Ferndale, WA, USA.
    28,387
    Nothing wrong with the "170" or "185" Champion Flathead as long as you don't plan on heavy loads, getting going Fast or a lot of high speed cruising without Overdrive or a speed friendly Car Axle Ratio.
    Just don't race any Honda's at a stoplight!
    Jan 2013
    british columbia
    1,160
    Yes Richard this is only an example, they are two separate engines one is upright the other is resting on its head and the camera was upside down so the numbers would be right side up. tricky.
  15. #15
    President Member Kurt's Avatar
    Jun 2005
    YatesCity, IL, USA.
    1,234
    This truck has been floating around on Illinois Craigslist for a few months. It is a later truck with an earlier flathead transplanted in it. It has the later suspended pedals. I have not seen the serial plate. As others have said, that will tell the story.
    1962 Champ
    51 Commander 4 door
  16. #16
    Champion Member
    Apr 2018
    Maryland
    6
    seller sent the engine number, but no picture of the data plate. It does have overdrive. engine number is i05633i
    He also sent me G 629 but did not specify where he got it from.
    thanks
  17. #17
    Dec 2005
    Ferndale, WA, USA.
    28,387
    I get 1056331 = a 1953 Champion.
    '53 Starting Engine Number was> 1,004,001 and 1954 started at > 1,090,101
    http://www.studebakerdriversclub.com/tech_6data.asp
    What were they? 85 H.P. on a 60 degree day at Sea Level, downhill!
  18. #18
    Champion Member
    Apr 2018
    Maryland
    6
    err, so not a great engine to have in the truck. Makes me wonder why go back 10 years if you need to replace an engine...
