Results 1 to 7 of 7
Thread: Starter
    Speedster Member
    Jun 2010
    215
    Starter
    Does anyone know what the clearances are supposed to be between the armature and the fields on a six volt starter.
    Jerry Kurtz
    Dec 2014
    Minneapolis
    4,251
    I've never seen a spec, but by how much the drive end bushing wears when the armature starts to rub, I'd say about .005" to .008".
    Commander Member
    Jun 2008
    Saugerties, NY, USA.
    60
    jerezstude;
    Unless you are building your own starter; why would you need to know. You could place the armature inside the starter resting on one of the field coils and measure the clearance with a feeler gauge. If there is any play in the rear bushing the armature will hit the field coils.
    Ron
    Speedster Member
    Jun 2010
    215
    I am having a continuing problem with a six volt starter have done all the normal things, heavy cables, ground wire to starter. Tore several starter apart and found most have .0355 or more clearances. I thought that was excessive so that is why I asked.
    Jerry Kurtz
    Dec 2014
    Minneapolis
    4,251
    Have you used a growler on the armature?
    Do all the springs have good tension?
    If you bench test a starter, you better have some heavy duty jumper cables. Most cables are too light for bench testing.
    Speedster Member
    Jun 2010
    215
    Yes I have a growler and have used it on the armature, actually I have tried several armatures. The brush springs all have good tension. When it is bench tested it runs freely.
    Jerry Kurtz
    Apr 2016
    Westbrook, MN
    570
    Had a starter problem. It was "dragging" If your's is dragging you can see the rub spot on the field coil. The guy at Wabasso Electric Motor [507-342-3701] is a wizard with starters and generators shaved a cat's whisker off the armature and viola--just like new. The most common cause for the armature dragging on the field is worn bushings. A growler is just a gadget that tells you if the armature might be shorted out. I just use a VOM to do that. Be sure bushings are good-rplace them --they are cheap. Good Luck Jerry
