My recently acquired 1965 Daytona's ignition switch falls out when rotated. It was fine when I bought it in May. Oddly enough there was an article from Turning Wheels, (OCT 99), about the problem of the bezel failing and a failed bezel in the glovebox. I did not even read it until the bezel failed again. The previous owner was wise enough to add a 30 amp fuse to the wire feeding the switch so no harm. I bought a new bezel from S.I. and installed it, the switch still falls out. There is no "spacer" on the switch. S.I. lists the switch housing itself as a through 66 but the spacer as only through 64. I ordered a new spring and spacer for a 64 from S.I. tonight, will that fix it? I have a way to clamp the housing behind the dash figured out but would rather leave it stock if I can, it is a very tight spot.
JK
JK
