Results 1 to 10 of 10
Thread: Need Info on 1965 Drive train
    Speedster Member
    Dec 2006
    eau claire, wisconsin, .
    181
    Blog Entries
    1
    Hi, I may have posted this before, but here I go again. I have a '65 Wagonaire that originally had a 3 on the tree with o/d. That system was removed in favor of putting a Chevy bell housing, and Chevy transmission thus converting it to a floor shift.
    So my question is, what do I need to return the drive back to original?
    Will a bell housing from previous years Larks fit on the Chevy 283? Or is the '65 & '66 bell housing different?
    In essence, I figure that I will need every thing from the engine back, including the fly wheel, and possibly the drive shaft.
    Would also need the shifting linkage. The steering column with its shifting mechanisim was left intact. A o/d cable would be needed too.
    Apr 2005
    Great Falls VA
    3,269
    The bellhousing you need was a special casting used mainly by the Checker Cab Co, when they were using Studebaker frames. They were also on RQA Avantis (1966-70). Probably quite a rarity now..
    64 GT Hawk (K7)
    1970 Avanti (R3)
    Speedster Member
    Dec 2006
    181
    Blog Entries
    1
    RAQ? I'm not familiar with that term.
    Speedster Member
    Aug 2008
    Devon, Alberta, Canada.
    323
    The RQA is the first digits in the serial number of an Avanti II. It used a lot of old original Stude stuff. The bell housing is a Stude special casting and is not so easy to find. I appreciate that you want to convert BACK to original and I suppose finding the old original parts from your car isn't going to happen so be patient, keep a big bag of money handy and make all the right inquiries to the parts vendors, Studebaker Swap Pages and wherever else you can think of to find said scarce parts. Good luck.
    Silver Hawk Member
    Dec 2004
    Trochu, Alberta , Canada.
    5,292
    You could also look for a Chevy Saginaw 3-speed with overdrive, install that, and few people would know it was not stock. And I think some of those Saginaws had syncro low gear, too. I see the odd one at swap meets. The OD parts are standard Warner gear stuff, so the Studebaker OD accessories will work.
    President Member r1lark's Avatar
    Oct 2004
    Winston-Salem, NC, USA.
    4,103
    Blog Entries
    36
    Quote Originally Posted by 64V-K7 View Post
    I had never heard before that Checkers used Studebaker frames. Details please.
    Paul
    Winston-Salem, NC
    Apr 2005
    Great Falls VA
    3,269
    Quote Originally Posted by r1lark View Post
    Yes, this statement has to be straightened out. It wasn't frames they used, rather the PowerShift (type) or FMX type transmissions in 65/66. They were using the GM 327/350 engines in their cabs. I have a 70 RQA and the original drivetrain was an FMX with a Powershift quadrant behind a 350/300 SBC.
    64 GT Hawk (K7)
    1970 Avanti (R3)
  8. #8
    Speedster Member
    Dec 2006
    181
    Blog Entries
    1
    65 stude drive train
    Thanks! That's a good idea. But what do I do for shift linkage?
  9. #9
    Dec 2005
    Ferndale, WA, USA.
    27,679
    Just modify your Borg Warner 3 Speed O.D. Shift Levers to fit the GM Trans. if you can cut and weld, if not they have to be made.
    Apr 2006
    Union Gap, Washington, USA.
    579
    Boy you guys are so wrong. 65 Studebakers used a standard GM bell housing with an adapter plate for the Borgwarner manual transmission. The BW transmission had a special input shaft with the GM size pilot and clutch splines. If I was you I would look for GM five speed transmission to get Overdrive or a Gm three speed OD. The five speed would be the easiest as you do not need the clutch hydraulics so you have a wider selection of years for the transmission. I converted my 65 to a Saginaw three speed back back in 1982. Still have the adapter sitting in my Studebaker stuff.
    65 2dr sedan
    64 2dr sedan (Pinkie)
    61 V8 Tcab
    63 Tcab 20R powered
    55 Commander Wagon
    54 Champion Wagon
    46 Gibson Model A
    50 JD MC
    45 Agricat
    67 Triumph T100
    66 Bultaco Matadore
