Results 1 to 11 of 11
Thread: 57 Commander hood alignment
    Jul 2013
    Shorewood Illinois
    1,243
    My hood is close to the left fender at the front with a gap at the passenger side of the cowl. What do I loosen to make the adjustment ? These two bolts on each side?image.jpgimage.jpgimage.jpg
    Mar 2017
    Parkton, MD
    123
    There are actually three bolts if you look closely. To adjust what you describe, only loosen the bolts for the passenger side hinge and tap it slightly to the rear of the car. Tighten and try.
    Jul 2013
    Shorewood Illinois
    1,243
    Yes, I noticed the third bolt. Thanks Ross.
    1,431
    The proper sequence for aligning a hood is to adjust the gap at the cowl and then adjust the fenders to the hood.
    Sounds like yours is just to far forward on the passenger side. Those bolts would be on the edge of the hood, not at the firewall and hinge as pictured.
    Jul 2013
    Shorewood Illinois
    1,243
    What bolts on the edge of the hood? What edge? There are two vertical parts of the hinge that the hood bolts to, two on each side. Ross’s suggestion makes sense.
    1,431
    Sorry, not edge, but bottom of hood bracket at top of hinge, but not the bolts on the lower part of the hinge as pictured. Those will adjust the back edge of the hood up and down at the cowl. Sorry for the confusion.
    Quote Originally Posted by tim333 View Post
    Jul 2013
    Shorewood Illinois
    1,243
    These bolt holes are not slotted so I don’t see how the hood can be moved.image.jpgDon’t know why pic is sideways, left side is the top.
    1,431
    OK, from this picture I can see there are horizontal slots in the hinge bracket for forward/backward adjustment and from your first post picture I can see that there are vertical slots in the body bracket for up/down adjustment. This is different then my Lark types and more like my 55 President.
    Anyway, the 2 bolts and nuts you pictured on your first post ARE what adjusts your hood forwards and back by loosening the bolts and sliding the hinge forward or backwards. However, loosening those bolts will also allow the hood to change the up and down position.
    I would loosen the bolts slightly and slide the hood back where you need it and when tightening the bolts make sure the hood is still in the correct up/down adjustment. Try to mark the hinge to get the same angle on the body bracket as it is now. Paint and crud may leave some tell tail marks you can see. Just having the before picture will give you some reference. I can see that the front of the hinge is slightly higher then the rear from the picture.
    It's a little different and more tedious task to adjust then the later design. Get some help to hold that hood up and move it.
    Sorry for the earlier confusion.
    Good luck.
    Jul 2013
    Shorewood Illinois
    1,243
    Thanks Thunderations.
    Jul 2013
    Shorewood Illinois
    1,243
    Tapped the lower bracket on the passenger side rearward about 1/4”, hood is aligned now.
    1,431
    Good deal. As always, if a little tap won't fix it, get a bigger hammer.
