Results 1 to 4 of 4
Thread: Tire Sizes where Not , trying to Match factory
    Sep 2016
    Bay Area
    91
    Has anyone tried a P225 R60 15----Radial on anything Studebaker , mid 50's on thru..... you get a lil extra width ( 8.9) from stock ( 8.5) yet the tire is a tad shorter, so you see a little more of the tire/ white wall ??
    President Member fatboylust's Avatar
    Jun 2010
    Bremerton WA
    509
    Tire width, wheel width and wheel backspace/off-set all need to be considered as well. The first picture below is an 8" wide tire on a stock/original 5" wide wheel. Note the dark black strip where the tire was rubbing on the top A frame when the wheels were turned to the to the stops. The second picture shows the bright shinny edge where the tire rubbed on the A frame. This is from a 1952, however the basic configuration of Studebaker steering remained little changed from 1951 to the end.
    8,269
    Yes, with the correct backspace wheels, 225 can fit and will work well.
    Yes, it's a bad idea to install them on Studebaker wheels. They're just not strong enough to withstand wide radial tires.
    Sep 2016
    Bay Area
    91
    Say for example-mid 60's Ford rims yes, Not factory rims
