Results 1 to 16 of 16
Thread: '61 Lark shifting issues
    Speedster Member GTHawk's Avatar
    Oct 2009
    Wi
    247
    My 1961 Lark doesn't want to shift into high when I'm accelerating on the highway. So far it sometimes eventually shifts after I've been driving it awhile. Any suggestions?
    don
    4,875
    Would you care to say what engine and transmission combination you have?
    Oct 2009
    Wi
    247
    259 v8 3 speed automatic
    don
    1,612
    First thing to check is the fluid level.
    Is this problem something new or have you just acquired the vehicle and it has this problem?
    There is a sequence of adjustments to make on the accelerator linkage and kick down that affects the speed at which the trans shifts.
    Get the instructions for step by step adjustments and try that first, after checking the fluid level.
    Jan 2014
    marana, Arizona
    723
    Be sure to check the transmission warmed up and in drive position to get the actual fluid level not in Park. Be sure to block your front wheels before preforming this procedure! Good luck.
    1,325
    Seems like my old 63 wagonaire did the same. throttle rod between trans and bell crank on engine needed adj.had to let off gas to get it to shift. adj involved a press guage on trans and a trusted asst. manual is helpful here. Luck Doofus
    Gainesville, FL
    14,777
    Failing engine/transmission mounts will also change the throttle rod adjustment.
    Oct 2009
    Wi
    247
    Did not know it should be in drive. Will try this and I'll check out the manual and the kick down lever.
    don
    Jan 2012
    Seattle WA, USA.
    997
    So your trans does no even shift once in drive? If it does shift once in drive, it is operating normally. Unless the valve body has been altered, you have to shift manually into L to access it. Just restating something that I think that you probably already know.
    Oct 2009
    Wi
    247
    Quote Originally Posted by Hallabutt View Post
    It has occasionally gone into high. Now, with manual shifting, if I start out in low, it will go into second and stay there. If I start out in drive (or second) it stays in second. The fluid seems to be okay. It'll be next week before I can get it on my lift and replace the filter and check the downshift linkage. If I remember right, I think I had this problem before and I changed the filter and it helped for awhile. I'm going to try that again. Will keep you posted.
    don
    1,325
    GT Hawk if you have to order a press gauge be sure to get a 6 ft hose model.that will just hang inside the vent window to read easily. also dont panic if the throttle rod pops off the bellcrank up front it will snap into place.BTDT yesyerday. had to shorten rod 12 turns to get press right. Luck Doofus
    eau claire, wisconsin, .
    183
    1
    Just a thought. Try Lucas oil for auto transmissions. A Stude friend of mine with a '55 Stude 3spd w/od was having shifting problems. He put in the Lucas gear weight lube, and now it shifts great.
    Oct 2009
    Wi
    247
    Just want to give an update on my Lark. I got it up on my lift, drained the fluid, cleaned the screen type filter (which was very dirty), checked the kick down linkage (which seemed to be okay), put it back together and it shifts now but sometimes not as soon as it should. We used Type F transmission fluid. Is this correct?
    don
    Jun 2017
    Washington
    133
    Could it be the vacuum modulator? My dad's 69 F250 had a modulator issue and it would shift too low, still kinda does. The modulators can be adjusted to allow for different shifts and stuff. I dont know if the almighty Studes have a modulator as my only Stude is my Lark which has 3 OTT+OD
    Good luck
    28,760
    Since Stude. Cars have No Vacuum Modulator, control and firmness of shifts is ALL about that Throttle Pressure Control Rod adjustment!
    It is not a kickdown Rod or a downshift Rod.
    Oct 2009
    Wi
    247
    I learned a new term (Throttle pressure control arm) How do I check pressure?
    don
