Thread: Change in Exhaust Manifold for 1950 Commander
    Does anyone know what changed in the Commander exhaust manifold during 1950?
    The parts book lists 515932 for engines before H391,863. 14A-17A
    The parts book lists 525769 for later engines.
    Puget Sound, , USA.
    4,237
    The early one has a two-stud exhaust flange. Apparently flange gaskets were being blown out often enough that they changed to a three-stud flange. However, a bulletin also says that by removing one stud and moving another to the provided hole , the new manifold can be used as a two-stud manifold.
    OK, thanks. I thought I was going to have to buy a manifold, but I'll try to free up my heat riser.
    The engine runs great the way it is, so maybe I should leave it stuck.
    1,613
    As long as it's stuck open, not part way closed.
    Puget Sound, , USA.
    4,237
    I think the early/late parts for the heat riser are different also.
