...do you know anyone who repairs car horns?
Horn Repairs...
I sent mine (from a 63 GT) off to this guy:
Specialty restorer and rebuilder of classic and muscle car & Truck horns. The Horn Works guarantees the end product will exceed original manufacturer specifications.
He was initially not used to dealing with Studebaker horns; I had to send him photos after which he agreed that he could fix them.
They came back as advertised and sound great.Jim K.
63 Hawk
Thank You.....
They came back as advertised and sound great.Lou Van Anne
62 Champ
64 R2 GT Hawk
79 Avanti II
Anyone know who might repair 6 volt horns?Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
Originally posted by ddub View PostAnyone know who might repair 6 volt horns?
I bought a missing horn for my 50 Land Cruiser from the junk yard.
Buying a good used horn might be cheaper than having one repaired.
Many times horns do not have to be rebuilt. Sometimes all that is necessary is an adjustment of the screw located on the case which will readjust the contact points making a better contact. I recently had to adjust the horns in my Avanti which now makes them sound like new ones. On earlier horns with the removable covers, the contact points can be accessed for cleaning and adjusting which restores a good contact. Bud
Originally posted by Bud View PostMany times horns do not have to be rebuilt. Sometimes all that is necessary is an adjustment of the screw located on the case which will readjust the contact points making a better contact. I recently had to adjust the horns in my Avanti which now makes them sound like new ones. On earlier horns with the removable covers, the contact points can be accessed for cleaning and adjusting which restores a good contact. BudPaul Johnson, Wild and Wonderful West Virginia.
This garage sale was posted recently. It looks like Spartan horns on one of the tableshttps://seattle.craigslist.org/oly/gms/d/huge-garage-sale-lots-of/6613300468.html It looks like the link didn't stay active through the transfer. Just search garage sale on the forum.Tom Senecal Not enough money or years to build all of the Studebakers that I think I can.
I'm sure there is a special wrench that was designed to turn those screws, but I've never seen one. I use pliers to turn the screws which I know isn't the best but they will work. Be careful when trying to turn the adjusting screw on the Sparton horns as they can be very easily broken, I learned that the hard way. My recommendation for the Sparton horns is to keep soaking the screw with penetrating oil until it breaks loose. The screw even when it isn't stuck has an interference fit to keep it from turning on its own, so be careful when trying to turn them. Bud
If I remember correctly, the later Sparton horns are riveted together which makes disassembly tough. If the horns have had a bunch of water get inside, they are usually done for as the water especially if it has any trace of salt in it corrodes the internals of the horn making repairs difficult if not impossible without the correct tools and a good stock of replacement parts. Bud
If anyone is interested, I found an adequate substitute for the horns on my 1962 GT Hawk. They're from Mac's Autoparts at https://www.macsautoparts.com/ford_t...95385/image/0/. Although they fit T-birds, they're good in appearance and have a nice sound. And they're only $72.99 for the pair. The dome is plastic but it looks pretty good. The only thing you have to change is the electrical terminal. The mounting brackets are perfect.
1962 GT Hawk
