Results 1 to 14 of 14
Thread: Horn Repairs...
    President Member Lou Van Anne's Avatar
    Jun 2009
    Stockton CA
    1,894
    Horn Repairs...
    ...do you know anyone who repairs car horns?
    Lou Van Anne
    62 Champ
    64 R2 GT Hawk
    79 Avanti II
    Speedster Member JimK's Avatar
    Nov 2008
    Los Alamos, NM, USA.
    355
    I sent mine (from a 63 GT) off to this guy:
    http://carhornrestoration.com
    He was initially not used to dealing with Studebaker horns; I had to send him photos after which he agreed that he could fix them.
    They came back as advertised and sound great.
    Jim K.
    63 Hawk
    Jun 2009
    Stockton CA
    1,894
    Thank You.....
    Quote Originally Posted by JimK View Post
    Lou Van Anne
    62 Champ
    64 R2 GT Hawk
    79 Avanti II
    President Member ddub's Avatar
    Dec 2005
    Centralia, WA, USA
    2,222
    Anyone know who might repair 6 volt horns?
    Don Wilson, Centralia, WA
    40 Champion 4 door*
    50 Champion 2 door*
    53 Commander K Auto*
    53 Commander K overdrive*
    55 President Speedster
    62 GT 4Speed*
    63 Avanti R1
    64 Champ 1/2 ton
    * Formerly owned
    Dec 2014
    Minneapolis
    4,827
    Quote Originally Posted by ddub View Post
    The same guy that repairs 12 volt horns should have no problem doing a 6 volt horn.
    I bought a missing horn for my 50 Land Cruiser from the junk yard.
    Buying a good used horn might be cheaper than having one repaired.
    Apr 2009
    Hawthorne, California, USA.
    1,909
    Many times horns do not have to be rebuilt. Sometimes all that is necessary is an adjustment of the screw located on the case which will readjust the contact points making a better contact. I recently had to adjust the horns in my Avanti which now makes them sound like new ones. On earlier horns with the removable covers, the contact points can be accessed for cleaning and adjusting which restores a good contact. Bud
    Silver Hawk Member 53k's Avatar
    Oct 2004
    Martinsburg, West Virginia, USA.
    5,986
    Quote Originally Posted by Bud View Post
    I agree. I have never sent out a horn for repair. The adjusting screw always worked for me.
  8. #8
    Aug 2016
    Elko NV
    795
    This garage sale was posted recently. It looks like Spartan horns on one of the tableshttps://seattle.craigslist.org/oly/gms/d/huge-garage-sale-lots-of/6613300468.html It looks like the link didn't stay active through the transfer. Just search garage sale on the forum.
  9. #9
    Jun 2009
    Stockton CA
    1,894
    Been using penetrating oil on my horn's adjusting screw....so far no luck....is there a special wrench used?
    Lou Van Anne
    62 Champ
    64 R2 GT Hawk
    79 Avanti II
  10. #10
    Apr 2009
    1,909
    I'm sure there is a special wrench that was designed to turn those screws, but I've never seen one. I use pliers to turn the screws which I know isn't the best but they will work. Be careful when trying to turn the adjusting screw on the Sparton horns as they can be very easily broken, I learned that the hard way. My recommendation for the Sparton horns is to keep soaking the screw with penetrating oil until it breaks loose. The screw even when it isn't stuck has an interference fit to keep it from turning on its own, so be careful when trying to turn them. Bud
  11. #11
    President Member Ron Dame's Avatar
    Feb 2006
    Asheville, NC
    1,618
    Edit (removal) of my post.. I TRIED to disassemble mine, clean them up and get them working. They worked for a couple of honks, but both died again.
    If anyone has functional Avanti horns, I'm your huckleberry!
    Ron Dame
    '63 Champ
  12. #12
    Apr 2009
    1,909
    If I remember correctly, the later Sparton horns are riveted together which makes disassembly tough. If the horns have had a bunch of water get inside, they are usually done for as the water especially if it has any trace of salt in it corrodes the internals of the horn making repairs difficult if not impossible without the correct tools and a good stock of replacement parts. Bud
  13. #13
    Commander Member
    May 2018
    WA
    22
    I've seen them rust up pretty good and with a little cleaning and wd40 (sprayed directly into the bell of the horn) and then sdjustment they will usually work....quietly at first...once they free up they get louder.
  14. #14
    Speedster Member 56GH's Avatar
    Jul 2011
    Sarasota, FL
    370
    If anyone is interested, I found an adequate substitute for the horns on my 1962 GT Hawk. They're from Mac's Autoparts at https://www.macsautoparts.com/ford_t...95385/image/0/. Although they fit T-birds, they're good in appearance and have a nice sound. And they're only $72.99 for the pair. The dome is plastic but it looks pretty good. The only thing you have to change is the electrical terminal. The mounting brackets are perfect.
    Bill L.
    1962 GT Hawk
