Results 1 to 18 of 18
Thread: Removing Rusted Nuts With a Candle
    Jun 2016
    Riverside, CA
    28
    Cheers,
    JOE
    "After all is said and done, a hell of a lot more is said than done"
    Clark Olmstead
    Apr 2017
    227
    Im pretty sure it has something to do with the wax getting into the cracks and crevices to help lubricate.
    An engine builder in our Model A club reports good success using the wax method. Heat the head stud red hot, then let it cool until the wax just melts when he lays it on the sides of the studs. Let it cool, then try to remove the studs. I haven't tried it yet, but will give it a try the next time I need to remove head studs.
    Jan 2009
    Citrus Springs Florida
    970
    Jim Pepper has tried this and has reported it really does work just as the guy demonstrated. If there is anybody you can believe is telling you the truth it is Jim. keep this in mind and try it the next time you have a stubborn nut that wont break loose. Bill
    Jun 2005
    YatesCity, IL, USA.
    1,252
    This absolutely works. I tried it on a 3406 CAT diesel that had broken exhaust studs. I also used the method to get broken bolts out of a Farmall tractor I restored.
    1962 Champ
    51 Commander 4 door
    Above the Equator
    1,902
    Didn't work for me. The stud snapped before the nut ever came loose. And I heated and applied the candle a good number of times.
    I'm not the type of guy to spray a penetrant, count to five and wonder why it didn't work. I've had situations (numerous) where I used every "get it loose" product known to man including the much spoken of PB Blaster, acetone and ATF etc.. I've liberally applied it up to 5 times a day for a week, heat, no heat. NOTHING worked. In one instance (a steering rack nut on a not too old car) I had to carefully cut the nut off on parallel sides. It still took a bit of fine chiseling and one small section where it pulled the threads off the rack because the rust bond was stronger than the rack thread! And the metal of the rack was far superior to the metal of the frozen nut. BTW, under the nut, regardless of 25 liberal doses of penetrant over the course of a week, it was bone dry. I’m glad these methods work for some, but 80% of the time they don’t work for me.
    Mar 2008
    1,282
    In my experience red hot makes the bolt stud expand and crushes the rust that has set up house keeping in all the interstitials . It works exceedingly well.
    It requires MAPP gas at a bare minimum. Oxy acetyelene is vastly superior. Garden variety propane doesn't stand a chance
    Apr 2012
    princeton mn
    3,055
    It works. Used it to remove the water side block plug on a 460 Ford. Guy's brother said good thing I kept my mouth shut. Was going to say if this guffy idea works I'am buying lunch. Told him he was still buying lunch
    Speedster Member Santosh's Avatar
    Germany, Munich
    207
    It works, the heat expands the inner diameter of the bolt by the factor (1 + alpha) * delta T (alpha = extension coefficient) . And a little diffence in the diameter is an immense effort.
    Walter
    80 Fiat Spider
    63 Lark Regal 4 Dr. sold 2015
    60 Hawk sold 2017 in England
    56 Golden Hawk
    56 Corvette (John Cougar Mellencamp's C1)
    68 Volvo P1800S
    56 Jaguar XK 140 DHC
    http://www.speak-to-doc.de/oldi/
    1,325
    It will even work on some exhaust manifold studs. i drop an old deep well socket over the stud and heat the manifold.wax comes next. Luck Doofus
    5,981
    My mechanic son has used that trick many times with success. He has showed me, but somehow I always forget about it when I'm fighting a stuck bolt or nut.
    Commander Member JimKB1MCV's Avatar
    Nov 2013
    Southern Maine
    36
    Much used around ships and boats or any maritime application. Like every other tool in your toolbox, there are times when it won't do the job at hand but usually the wax (I was taught beeswax was preferred) will help start a stubborn nut or stud. Heat is usually your friend here, seems to aid the wax penetration. The trick sometimes is how much an where its used.
    An old Chief Engineer showed me the beeswax trick in the early 1960s.
    When I was the Old Chief in the 1990s a young !st Engineer showed me the trick. I was content to let him think he invented it.
    For a cheap source of beeswax, just go to Menards and buy a toilet setting ring for less than $2.
    It also works good for door latches and cam lock car top carriers to lubricate the aluminum levers you flip over.
    Mar 2010
    Lompoc, Ca
    1,404
    With a LIGHTER !!!!!
    No way.
    The wax works but requires more and longer application of heat.
    South Lompoc Studebaker
    Above the Equator
    1,902
    Quote Originally Posted by Santosh View Post
    Well, now that the "math" is explained it all seems so simple. LOL
    For those who remember the character Jeff Spicolli in the movie "Fast Times at Ridgemont High," maybe better said is: "So, like this humongous gnarly fireball puffs up the bolt and pulverizes the rust - pronto."
    1,206
    Quote Originally Posted by 55 56 PREZ 4D View Post
    No way.
    I have used the wax trick and it takes several applications over several days.
    A guy that size should have been able to remove those nuts with out said demonstration. I would say most members on this forum have used the wax treatment this is nothing new.
    May 2006
    San Diego, California, USA.
    8,832
    3
    I'd like to try that on the a-pillar door hinge screws... if I could get the frickin' candle back there
    Clark in San Diego
    '63 Standard (F2) "Barney"
    Apr 2017
    IA
    113
    An old blacksmith (well actually he is a young blacksmith) shared that if heat doesn't do it then you need lubrication I use heat from an acetylene torch to convince things to come apart, haven't had much luck with a candle. I have a friend that builds custom cars and he starts with throwaway junk and I guess he uses lard after he heats the offending fastener. I like the "rattle gun" because it vibrates and it's easier than pulling on a breaker bar.
