Results 1 to 6 of 6
Thread: '60 Lark VI clutch questions
    President Member LeoH's Avatar
    Oct 2012
    Sun Valley, NV
    2,110
    I have a '60 Lark VI wagon, 3pd/od. We're going to change the clutch and I don't have the manual with me at work and I don't have the clutch in hand. I understand that the 8 1/2" clutch is stock for that car, is the later 9+" clutch and plate able to be used, and if not why not? Is it because the flywheel surface only fits the 8 1/2"? We're trying to line up parts and if an 8 1/2" isn't available easily, would the larger package fit?
    Not being inside the car, I'm wondering. TIA
    Oct 2005
    St. Louis, Mo.
    1,629
    Just went through that with a friend, the issue is the holes for the pressure plate to attach to the flywheel The 9 1/8 plate has a larger diameter bolt pattern then does the 8 1/2.
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
    Oct 2012
    Sun Valley, NV
    2,110
    Thanks. That makes sense, but if you're not looking at the back of the flywheel and such....
    We'll likely have to order what we need after we get the clutch in hand. To be safe.
    28,779
    Quote Originally Posted by LeoH View Post
    /Cut/but if you're not looking at the back of the flywheel and such....
    So you are saying Leo, that you will search for a 9 1/2 Inch bolt pattern Flywheel then when your 9 1/2 Inch Clutch Disc and Pressure Plate arrives?
    Oct 2012
    Sun Valley, NV
    2,110
    No. I'm saying I'll wait until I see what the clutch disc is that I have in the car before ordering. Thank you for explaining to me why the 9 " clutch doesn't fit or won't work on my car when I'm doing my first clutch replacement. Very helpful.
    Jun 2017
    San Francisco, CA
    7
    Could be 8 inch. Eight or 8-1/2 inch are hard to find and usually require your core before shipment.
Tags for this Thread
