So when I picked up a 7E5 OHV six for my 7E5 project last July, the engine did not have a starter motor on it...
Person I got the engine from had a starter laying around, and tossed it into the truck so I would have something to "start" with - however, missing a couple of things.
First - the bendix drive ("Folo-thru" as labelled by the shop manual - it pulls the starter drive in toward the ring gear - opposite what other bendix drives do) does not have the set screw (that is what the manual lists it as - parts book calls it a pin...) which is supposed to keep the bendix on the armature shaft - part number is 1550897 - SI parts look-up function does not show anything.
Second - there were zero bolts to hold the starter to the bell housing. Two of the bolts are standard (3/8" - 24 x 1 7/8) with nut and lock washer. The third bolt only says "special" - pn 1685375 along with the standard 3/8 nut and lock washer. Again, online parts look-up shows nothing available. The shop manual does not say anything about a special bolt or where it might go.
So, any indications about what I need to be looking for? Thanks ahead.
