Results 1 to 3 of 3
Thread: 4-Speed Shifter Mods - Service Letters?
    Winston-Salem, NC, USA.
    4,103
    36
    Subject: 4-speed shifters
    Service Letter U-1963-1 dated October 29, 1962 details some modifications to the T-10 4 speed shifter -- primarily a new Shift Lever, nylon bushings for the Shift Lever Retaining Pin, a different spring washer, and a "Shifter Guide Sleeve" (boot) p/n 1559675 that was installed on the very bottom of the shifter lever where it rides in the Shift Lever Guide.
    There was a later modification that eliminated both the 1559675 Shifter Guide Sleeve and the original Shift Lever Guide with p/n 1563002 "Plate, gearshift anti-rattle".
    Question: was there a Service Letter that covered the new p/n 1563002 Plate, gearshift anti-rattle?
    Paul
    Winston-Salem, NC
    Marysville, Washington, USA.
    533
    While I don't have a copy of that service letter, I do recommend using the spring clip retainers rather than the plain cotter pins, as found in Mr. Gasket shifter bushing & clip kit # 11 , on the ends of the shift rods. Lou Cote
    Apr 2008
    Seligman, Az USA.
    4,997
    I've replaced the plastic bushings with brass along with the spring clip retainers. It helped but the Hurst shifter made it great.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
