Results 1 to 28 of 28
Thread: Get more out of the 170
    Commander Member km420's Avatar
    Shelbyville Il
    55
    I have a 61 Lark VI with the 170 and 3sp auto. I apologize if this has been answered before, but I can't find an answer anywhere.
    When driving down the road, I have no issues going 55, but anything above that and it doesn't want to cooperate very easily. I'm aware that may be the best I can do, but I'm wondering if there's anything I can do to get just a little more out of it. I would ideally like to be able to cruise at 65-70 if I were to take it on the interstate.
    Will a rebuild be necessary? What are my options to *slightly* improve performance? As far as I know the engine, transmission and everything else is all stock. Any advice is greatly appreciated and I'll try to answer back with any more information I can supply. I've had this Lark for nearly 2 years and still don't know much about it.
    Thanks in advance!
    Jan 2005
    Yakima, Wa, .
    1,472
    You may need to install a different rear end, one with a taller gear ratio. Check the differential and look for a tag with a number such a 4:10 or 3:55. My '60 Lark has the economy rear end ratio of 3:07 so it'll do 70 easy, but it also has a V8.
    547
    You should start with figuring out the gear ratio that the car has in it. If it is geared too low, you will never have much for top speed, although 55 is pretty slow for even a low gear ratio. The next thing that I would check, are normal tune up items like plugs, wires, points, cap, rotor, and how clean the carburetor might be. Last thing would be valve adjustment. If they are running a bit tight, it will affect performance. Others with more experience with the 6 cylinder will likely add to my response. Good Luck with it!
    Apr 2014
    Knightdale, NC
    845
    Some have replaced the 170's crankshaft with that from the earlier flathead 185, thus creating an OHV 185. But it sounds like that might be more than you're looking to do.
    Mike Davis
    1964 Champ 8E7-122 "Stuey"
    Puget Sound, , USA.
    4,116
    Are you saying the car just will not go any faster than 55? Or is it that you don't what to make the engine rev any higher? My '63 Standard with 6/AT will do 70 just fine. The RPMs are up around 3,000 at that speed though.
    Mar 2017
    Parkton, MD
    123
    Have very many miles on many 170s and even with the stock 3.73 axle you should be able to maintain 65+ easily even up pretty steep hills. They don't mind the revs at all. Just freshened up the 170 in my 63 convertible and found zero crank wear at 95,000 miles. Put it back together with new rings and drove it 4500 miles from MD to Utah and back last fall at 65-70. Just want to raise your expectations a bit for a stock engine. I like them. A lot. In contemporary roadtests they were faster than most base model competition and they are very "light on their feet".
    Adjust your valves to .027 hot and running which is a ten minute job on that car. Drop 60-70 bucks on points, condensor, rotor, cap, plugs and wires. Make sure the vac advance is good and the centrifugal works. Have someone press the gas pedal to the floor while you make sure the carb is opening all the way. Make sure your exhaust isn't crushed/ restricted. Heat riser is in the down position when its hot? Bring it back to a standard condition before you start thinking about modifications.
    4,090
    My 50 Champion with overdrive will do more than 55, but that's the speed I drive. I wish it had a 4.11 rear end instead of the 4.56 ratio. The engine sounds plenty busy at 55. The strange thing is my 50 Commanders and Land Cruiser are all about the same ratio with overdrive, and don't sound near so busy at 55 or 60.
    What size tires are on your Lark? As mentioned, I'd check the rear end ratio, and go for one in the lower 3's.
    6,996
    Strange that the Champion should have problems. My previous 52 Champion with a 4:56 and overdrive would cruise 70 all day very well. Have you put a tach on it to confirm the revs?
    Sometimes the roar of the fan makes the engine seem to be protesting. I drove my 71 Cuda without the fan once and was amazed at how much quieter it was.
    7,906
    Quote Originally Posted by km420 View Post
    When driving down the road, I have no issues going 55, but anything above that and it doesn't want to cooperate very easily. .. . . I've had this Lark for nearly 2 years and still don't know much about it.
    Nor do we at this point. As others have alluded to, this lack of detail is akin to being in a dark room, looking for a black cat, which may not be there. The OHV6 has a following here and you'll get expert advice, but they need something with which to work.
    1. Will the car actually hold 70, but just sounds strained to your ears? FWIW, today's better-insulated cars with double-overdrive transmissions and electric fans have re-educated our ears to never hear traditional engine noises. A low-geared Stude with the Swiss-cheese firewall and no insulation, by comparison, sounds like a threshing machine.
    2. Or does it actually begin to stumble and misfire above 55 MPH?
    3. What is the rear gear ratio? It's on a tag on the rear axle cover. After fifty-seven years, it might have been changed from the OEM ratio; or it could have been special ordered by a postman on the Wolf Creek Pass route.
    4. What tires are on the car?
    5. How many miles does the odometer show. (Never believe that to be a fact; but at least it's an indicator.)
    6. Have the brakes been checked for drag?
    7. Has the car received a thorough lubrication per the Shop Manual, including wheel bearings, engine oil and filter and transmission oil and filter?
    8. Has the engine received a complete tuneup, including new air filter, ignition points, condensor, rotor, cap, wires and plugs?
    1,431
    When I had my 63 Daytona with the 170 and automatic, it ran 70 just fine. Would never set a land speed record or win a 1/4 mile race, but that was not it's purpose.
    Wanting a little more performance, I started checking on improvements and the easiest change would be to a better carburetor. The one I was looking at was a Ford progressive 2 barrel that was used on Mustang V6 engines in the 80's. It's like half of a 4 barrel carb, running on 1 barrel and as needed the 2nd barrel opens up.
    I never made the modification and sold the car. I would have liked to see what improvement that would have made.
    Many years ago, playing with 40 horse VW engines, just adding a 2 barrel carburetor and improved exhaust would bump the HP up to 50-60.
    Shelbyville Il
    55
    I've had it just over 60, maybe touching 65, but I've not been able to touch 70. I figure a tune-up would be a good place to start, and that will be my first course of action in the next week or so.
    I've checked for a tag with a gear ratio and haven't been able to find one, it's been awhile though, so I'll check again.
    odometer reads around 45k.
    taller gears and a new carb are definitely things I'm looking into. I hadn't done much as I was looking at doing an SBC swap and have recently decided to just leave it as stock as possible.
    27,679
    If you follow Ross's advice in Post #6, I am sure the gremlins will come out, seriously!
    A poorly tuned engine with a ignition point gap almost closed will act like that, plus other "weaknesses" in other electrical components or their adjustment: Ign. Timing, Dist. Dwell, Valve adjustment, Carb. Linkage etc.
    Good luck with your analysis.
    Shelbyville Il
    55
    Thanks everyone!
    San Jose, California
    586
    Well something is wrong. You should be able to hit at least 90 mph without any problem. Follow the tune-up advice given and pay attention to the distributor advance etc. Check your compression to verify that you don't have any valve or ring problems.
    Report back and you will continue to get good advice from many of the people on this forum.
    David L
    Jun 2009
    Glendora, California, USA.
    1,531
    I put a 63 OHV 6 in my 59 Lark and it would do at least 100 mph, did it a couple of times, that was on the way to work so I backed off as the Highway Patrol dont like that sort of thing. I did have a completely upgraded ignition, no points, 8.8 wires, CDI, matching coil. Plus a 4bbl carb and a new exhaust with a Magnaflow muffler. Of course with all I did the suspension was upgraded too so it would be useful power.
    I did however have an overdrive and 4.10 rear. The gearing was excellent.
    https://www.youtube.com/watch?v=WsvL5Al61ic
    https://www.youtube.com/watch?v=e8CPsJJtWKw
    As mentioned before if all is as factory and no faults you should be able to get about 90mph. The original Flathead would do about 80mph.
    Len
    Sacramento, CA, USA.
    4,961
    Quote Originally Posted by BRUCESTUDE View Post
    I think you've hit the nail on the head. Just switch to a V8 and be done with it. The costs involved in getting a 6 to make any sort of power, (other than for racing), would go a long way to just switching over to a V8 and enjoy the good gas mileage and the driveability that'll keep up with any of the modern traffic without worrying about blowing up the engine.
    sals54
    Jun 2009
    1,531
    Too true. That is unless you really want to spend countless hours tinkering and don't mind the challengers involved. I played around with the original Flathead 6, then the OHV 6, mainly because I had never had a Studebaker 6 before, always had V8's.
    I eventually swapped out the OHV 6 for a Studebaker V8, which was the original plan before I purchased the car. Like I mentioned before, to me the 6 was a novelty but eventually that wore off and the practicality of the V8 overtook any previous interest in spending any more time and money making the 6 do the work of the V8. Turboing was next on the list for the 6. and I had one for the job. It would have been a novelty but I wanted reliable power with an easy to care for package, KISS.
    If I only I had spent those hours and dollars on the V8. On the other hand I now have experience with Studebaker sixes.
    Len
    3,652
    must be 100 octane gas out in CA.....
    Jun 2009
    1,531
    No, but I didn't want to get into all the fiddly things I did to get it to it's final iteration. Like I said many many hours.
    Len
    Shelbyville Il
    55
    as mentioned, I had considered doing a v8 swap, but decided to stick with the 6 currently.
    Since there's not much that I can tell actually wrong with the current motor, I decided to keep the 6 and put some cash aside over the next couple years to do a v8 upgrade the right way, and I'd rather build it over the next couple years instead of starting on it now and rushing it. I'll be getting the things needed for a full tune-up and begin doing that in the next few weeks, then begin looking into taller gears.
    Thanks again everyone! the help/advice is always appreciated.
    Millington Tn
    200
    If you can't find the ratio tag. You can jack up the rear and spin the tires one revalution. Then see how many times drive shaft turns. Will give you the ratio.
    Douglasville, Georgia, USA.
    3,091
    Quote Originally Posted by 70Avanti2 View Post
    Raise one rear tire off the ground. Turn it exactly 2 complete revolutions while counting the revolutions of the driveshaft. That will give you the ratio of the ring gear and pinion.
    Jun 2009
    1,531
    I did that. Good plan. I found it easier to get a hold of a rusted out hulk with a V8. All the things you need and you can scrap the rest. Then build the engine with no rush. The only thing that may differ is transmission choice. Better to decide now and plan ahead. Just ask away and the forum will help you out.
    Len
    4,961
    I can dig that. There are some fun things to do to a 6 to spruce up the power too. A turbo can add a little or a lot of power rather simply and cheaply. You don't need to go the fancy route, either. Add a turbo to the exhaust side, blow through the carb ,(if its sealed), or build a simple carb enclosure. Then keep the boost at about 6 psi. You'll have a little more power and not melt a piston, (as I did running 14 psi of boost).
    Or add dual exhaust and a little more carb, and you'll enjoy just a tad more power, (maybe 10 more HP), but it'll drive much better and have better throttle response.
    Either way, enjoy the ride, doing it your way.
    sals54
    Shelbyville Il
    55
    One last question on this topic; would you upgrade to a Pertronix ignition (and does anyone know what part number I should be looking for) or just do the points, wires, plugs etc....
    Thanks again!
    4,090
    I like my original points ignition system. I've never had one fail yet.
    Mar 2017
    Parkton, MD
    123
    I am running stock points etc in all my cars. Every 20K or so I have to do a tuneup. They all start instantly. I have heard many stories of vast performance improvements when installing Pertronix etc. but they were invariably comparing with a system on its last legs. I have tried electronic ignition on several older cars but without any outstanding improvement in starting or economy compared to regular ignition in standard condition.
    With the revs and compression ratios we're talking about with a 170 points will do just fine. My 62 will pull the steep hill on the interstate near me at 75 in OD--indicated 80.
    4,090
    That reminds me, in 1966 I installed transistorized ignition on my 55 Chevy, and it went out 5 days later on my way to work.
    Then in 1977 I installed electronic ignition on my 1971 IH Scout 800B, and it lasted less than a week.
    Points have been great and totally reliable.
