Results 1 to 17 of 17
Thread: 53 coupe air conditioning
    United States
    18
    I plan to install air conditioning on my 53 Commander coupe, and concerned about hood clearance. I plan to use factory compressor brackets from a later Hawk. Also use a sanden 508 compressor using an adapter to the factory bracket. I am using a Avanti engine mounts to provide more clearance. Will my efforts be in vain, or will I have hood clearance?
    1,325
    If your compressor has rear line ports probably ok. side inlet exit can cause problems. proceed with caution. Luck Doofus
    United States
    18
    It does have rear ports. Thanks
    Poteau, OK
    192
    1
    I installed A/C on my '53 C/K and could not use it much in hot weather as there was insufficient air intake to keep the radiator from boiling. I used an auxiliary fan and still had problems. I wish you good fortune. Chet445
    Oct 2010
    Dundee, Oregon
    3,170
    Will your car need to be converted to 12v to make the system work?
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
    United States
    18
    Yes, it is converted to 12v already
    United States
    18
    Thanks for your reply. The overheat problem you have is discouraging! I will be using a studebaker HD three core radiator, and auxiliary fan. I can only hope for the best. What bracket did you use?
    President Member 55coupe's Avatar
    Jan 2009
    Citrus Heights CA, , .
    664
    I used the top mount for the compressor don't do it. put it on the side where the generator is then put your generator on the driver side. that way you should be able to use the fan shroud. I had to modify the ---- out of my shroud so that's my 2 cents. The other thing i would suggest is use a unit that give you air, heat and defroster it will tuck up under the dash more. As far as over heating I'm still not sure I have that under control , 3 core aluminum radiator , 18 inch flex fan manual style , camaro air dam. Also make sure your vacuum advance is working if not you could heat up at highway speeds. Oh my car is a 55 coupe with a 53 face lift 289 3sp w/od.
    United States
    18
    Thank you for your reply. Installing the generator on the left side creates another problems as I have Hawk power steering installed. I know some people install the generator in the "vee" and that is still a possibility.
    1,325
    The bracket i am using mounts under "T" stat 4 bolt housing and one leg to upper water manifold leg. comp sits between left valve cover and oil filler. alt mounts in usual position.Luck Doofus
    Newark, DE
    1,514
    Buy the Vintage Air bracket w/ PS option.
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    Gainesville, FL
    14,777
    United States
    18
    Thanks for the picture. It is a possibility, but my Eaton P/steering pump would be a problem for me I'm sure.
    United States
    18
    I will end up doing that I'm sure.
    Quote Originally Posted by mbstude View Post
    That's beautiful. You need to come to the land of mosquitos and do my 50 engine compartment.
    What brand is the black paint on the valve covers and shroud?
    1,325
    That looks like a satin black engine paint.Way to go matt!!! hey to everybody! Doofus
    Fort Pierre, SD, .
    998
    here is what I did on the Speedster. Used a Lincoln/Tarus 2 speed fan which includes the shroud. It requires an alternator as it takes about 50 amps when kicking on IIRC> as well as a relay setup. I built the alternator bracket.
