Page 2 of 2 FirstFirst 12
Results 41 to 53 of 53
Thread: Tire suggestions for a Hawk GT 62
  1. #41
    860
    Quote Originally Posted by Topper2011 View Post
    Off topic, but can you elaborate on the disc brake conversion?
    I turned down the Stude hubs to fit inside the Mustang rotor and fitted the Mustang studs to them with .020 wall tubing spacers. The Mustang Studs are longer and have a sholder to locate the rotor. I also added an aluminum ring to the snout of the hub to make the wheels "hubcentric" instead of "lugcentric", but that has nothing to do with the brakes.
    Made this caliper mount from 3/8" steel plate:
    Bolted it in place of the drum brake backing plate, slid the rotors on and bolted on the calipers.
    I did the same for the rear. The adapter is almost identical except for the mounting holes, but the caliper needs some shimming off the adapter plate to compensate for axle shims.
  2. #42
    Mar 2018
    Los Altos CA, USA
    118
    Wow, thanks. PM sent.
  3. #43
    Feb 2018
    Mansfield Texas
    14
    Would enlarging the rotor hole work the same as turning down the Stude hub?
    you should start mass producing the adapter plates!
  4. #44
    Feb 2018
    Mansfield Texas
    14
  5. #45
    Mar 2018
    Los Altos CA, USA
    118
    Quote Originally Posted by Chartrain View Post
    Yes, I would buy that.
  6. #46
    860
    Yes, but the standard rotor, that wil fit inside a 15" wheel isn't thick enough to take anything out of. If you want to use 17" wheels the 13" rotor from the Mustang cobra will slip right on. Not sure if bracket would need to be modified to move caliper or not. The Cobra caliper is slightly different.
  7. #47
    Speedster Member R_David's Avatar
    Sep 2011
    Boston, MA
    440
    2
    Here are my new Coker 215/70R15. They did cost an arm and a leg however, I see them as not just a tire to drive around on but an accessory that makes the car look better. Costs were: $912 with shipping, plus $140 for mounting, balancing and valve stems. Total cost $1,052. I plan on replacing them every six years, so that makes my monthly cost of these good looking and safe tires to be $14.61 a month. Totally worth it in my humble opinion.
    1961 Flamingo Studebaker Hawk
  8. #48
    860
    $1052 wow! That's what it cost me to put tires on 3 cars and my truck plus replace a truck tire when a valve stem broke on the freeway, and have enough left over for lunch. And they call Studebaker owners CASO! Not from where I stand.
  9. #49
    Sep 2011
    Boston, MA
    440
    2
    Just for reference, here are what those Coker radial 215/75R15's look like when installed. Pretty spiffy!
  10. #50
    631
    All this talk of Ford wheels will kill someone! IF YOU USE A FORD WHEEL USE FORD LUG NUTS!!!!! They are larger and are made for the larger hole in the Ford rim. Studebaker lug nuts are too small and won't seat properly. Dangerous combination espesially if you try to dodge that skunk in the road.
  11. #51
    Douglasville, Georgia, USA.
    3,288
    Talking about Ford wheels has never killed anyone and probably never will. Using Studebaker lug nuts with Ford wheels may, possibly, sometime in the future in an alternate dimension may cause a death. I, personally, have not yet heard of anyone being killed in an accident caused by incorrect lug nuts.
  12. #52
    3,672
    Quote Originally Posted by GTCruiser View Post
    Have had the Cooper 205's on my '64 Hawk for four years with no issues.
    215 coopers look better
  13. #53
    Kentucky Bluegrass
    2,968
    Had a chapter meeting back in Texas @1997. A member who drove 100 miles or so from Houston was pulling through the grass to park at the end of a row of cars when the left front wheel simply rolled off the drum and fell flat on the ground. Driver pulled forward another vehicle and backed the Hawk into the line up. Studebaker lug nuts were all still on the studs and the Ford wheel had pulled around them. He stated that it felt a little wobbly from time to time on the highway...
