Does anyone know: Can you install a Pertronix electronic ignition with the OEM Tach like on a 58 Packard Hawk without changing the tach?
Pertronix conversion with OEM Tach
If your PH has the wafer type tach drive, that fits between the cap and distributor body, as 56-57 does, then the answer is yes. No problem with the Pertronix. Also, pretty sure there is no problem with the later tachs and Pertronix, i.e. the GT Hawks'. I converted a 62 and a 63GT to Pertronix, and do not recall any problems with either car's tach. So no matter which type you have, I'd still say no problem with the tach & Pertronix combo.
Originally posted by GTHawk View PostJust ordered one from him along with the high voltage coil.
Thanks.don
If you still have the Original SINGLE Point Prestolite Distributor, you will need to purchase the Igniter III Pertronix Module with the Rev Limiter.
But unless you are drag racing it should not be any harder to install, just leave it at the Factory "Street" Setting. You will also need another 40,000 Volt Coil.
I have Sold and used quite a few Pertronixs units with no problems.StudeRich
Originally posted by StudeRich View PostIf you still have the Original SINGLE Point Prestolite Distributor, you will need to purchase the Igniter III Pertronix Module with the Rev Limiter.
I have Sold and used quite a few Pertronixs units with no problems.don
If you can not find the resistor , look for a purple wire that was used instead.
It is resistance wire.
The purpose was to reduce the voltage to the coil once the engine was running.
This reduced the wear and pitting of the points.
When you engage the starter solenoid there is a set of contacts in the solenoid that put full voltage on the coil when the solenoid is engaged for easier starting of the car.
Once the solenoid is disengaged , only reduced voltage goes to the coil via the purple resistance wire from the ignition switch.
This system was problematic because at times the resistance wire would become so hot that it melted the insulation.
The nichrome resistance wire had crimped terminals with did not do well with Nichrome wire.
I soldered the Nichrome resistance wires on my car or replaced it with regular copper wire and used a resistor like the later systems.
