Results 1 to 9 of 9
Thread: I Need Parts for a 1965 Automatic
    President Member irish's Avatar
    Aug 2009
    Owasso, OK USA
    611
    I'm looking for the parts needed to connect a flight-o-matic transmission to a Chevy engine. This is a 1965 Cruiser that was originally a 283 with an automatic. I got the car without an engine or transmission, but I have a 283 and an automatic out of a 1964 Cruiser. So I assume I need at least a torque converter housing. If you know the parts I need and/or if you have the parts let me know.
    Thanks,
    Joe
    1962 Daytona
    1964 Cruiser
    And a few others
    1,613
    Are you wanting to restore this car to original or make a nice driver?
    If making a nice driver, bolt a GM AOD behind the 283 and drive away. Lots of people putting those trans behind the Studebaker engines using a pricey adapter and you can do it without adapting anything. Might need to have a driveshaft made or one shortened, but that's pretty easy.
    Aug 2009
    Owasso, OK USA
    611
    I've done AOD conversions before, this car has 3.07 gears so I don't need overdrive and I have a flight-o-matic transmission I would like to use.
    Thanks,
    Joe
    1962 Daytona
    1964 Cruiser
    And a few others
    1,613
    How about just using a Turbo 350 and at least having the low gear take off?
    Quote Originally Posted by irish View Post
    Thanks,
    Joe
    2,797
    Did you mean a 289 out of a 1964 Cruiser or a 283 out of a 1965/66 Cruiser
    5,470
    I have a Flightomatic that was used behind a 283, and the engine it came behind. So I should have all the parts you need. Flightomatics for 283's used a cable-operated throttle valve, and I believe they all also had water cooling.
    Aug 2009
    Owasso, OK USA
    611
    Thanks Gord for the information. I didn't realize the transmission on a 65-66 was different than the one's used on a 64. I wonder if I could still use the 1964 transmission. Otherwise I may just use a TH350 automatic.
    1962 Daytona
    1964 Cruiser
    And a few others
    Feb 2013
    Ohio
    33
    I have a 65 Daytona that someone changed the transmission to a TH 350 before I purchased it. Works great and the only negative thing I notice is the shifter quadrant does not match the order of the gears in the GM transmission.
    Apr 2008
    Seligman, Az USA.
    5,062
    I seem to remember that 60's Jeeps had the same shift indicator bezel but the lens inside contained the now common PRND2L. I've looked for it on some Jeep vendors site hoping that someone had made some repro's but so far come up empty.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
