Thread: Repainting inside of horn button
    President Member lelshaddai's Avatar
    Aug 2015
    Mesa, Arizona
    509
    I am trying to repaint the read inside of a 51 Commander horn button. What is the best way to remove the old red paint? The emblem is still good so I only want to remove the red without messing up the clear part or the emblem.
    51 Studebaker Starlight State Commander Coupe
    53 Studebaker Starlight Regal Commander Coupe
    62 Volvo PV544 Sport
    28,385
    A very tricky job at best. Notice that they always sealed the Colors in with a Dull, Metallic, Aluminum Silver Top Coat.
    Also, be sure to get a Deep Burgundy with a lot of Blue in it, to replace the Original which was NOT Red.
    President Member 2R5's Avatar
    Dunnville, Ontario, Canada.
    4,952
    213139B7-E6D1-42BB-A0DD-C8A3BBAB0E65.jpgThis what it should look like
    3,696
    Wet sand paper. Start with 600 to 1000 grit. finish off with rubbing compound before painting. cheers jimmijim
    S RR Valley, ND, USA.
    2,424
    I tried to repaint a exterior plastic emblem like this once... Plastic looked good and ~seemed~ to be crack free. I forget what I used to get remaining old paint off, probably some solvent that appeared not to attack the plastic. Anyway, before repainting, I wiped it down with some thinner or alcohol and ~that~ wicked into hidden crazing cracks and ruined the appearance from the outside side. It would not evaporate either and I ended up painting it as-is. Look not so good. In hindsight, maybe if I had tried some low heat like a hair dryer I could have got the thinner out of the cracks.
    Short reply, is be careful what you use to clean it up!!!
    Jeff in ND
    4,642
    I have to do the same thing for a couple of identical horn buttons for my 1950 cars. I would try removing the old paint by scraping it with your fingernail.
    4,727
    I second the fingernail technique and suggest an orangewood stick that ladies use to push their cuticles.
