Results 1 to 7 of 7
Thread: Repainting inside of horn button
Hybrid View
Previous Post Previous Post   Next Post Next Post
    President Member lelshaddai's Avatar
    Aug 2015
    Mesa, Arizona
    569
    I am trying to repaint the read inside of a 51 Commander horn button. What is the best way to remove the old red paint? The emblem is still good so I only want to remove the red without messing up the clear part or the emblem.
    62 Volvo PV544 Sport
    Dec 2005
    Ferndale, WA, USA.
    28,760
    A very tricky job at best. Notice that they always sealed the Colors in with a Dull, Metallic, Aluminum Silver Top Coat.
    Also, be sure to get a Deep Burgundy with a lot of Blue in it, to replace the Original which was NOT Red.
    President Member 2R5's Avatar
    Oct 2004
    Dunnville, Ontario, Canada.
    4,985
    213139B7-E6D1-42BB-A0DD-C8A3BBAB0E65.jpgThis what it should look like
    Oct 2004
    Dothan, Alabama.*******SDC member
    3,717
    Wet sand paper. Start with 600 to 1000 grit. finish off with rubbing compound before painting. cheers jimmijim
    Anything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
    President Member Jeff_H's Avatar
    Dec 2004
    S RR Valley, ND, USA.
    2,448
    I tried to repaint a exterior plastic emblem like this once... Plastic looked good and ~seemed~ to be crack free. I forget what I used to get remaining old paint off, probably some solvent that appeared not to attack the plastic. Anyway, before repainting, I wiped it down with some thinner or alcohol and ~that~ wicked into hidden crazing cracks and ruined the appearance from the outside side. It would not evaporate either and I ended up painting it as-is. Look not so good. In hindsight, maybe if I had tried some low heat like a hair dryer I could have got the thinner out of the cracks.
    Short reply, is be careful what you use to clean it up!!!
    Jeff in ND
    Dec 2014
    Minneapolis
    4,827
    I have to do the same thing for a couple of identical horn buttons for my 1950 cars. I would try removing the old paint by scraping it with your fingernail.
    Apr 2005
    California
    4,875
    I second the fingernail technique and suggest an orangewood stick that ladies use to push their cuticles.
    60V-L6 - 60 Lark convertible
