I agree, with the logic of starting with the simple stuff first. The solenoid is not clicking yet so the battery is not TOTALLY fried.If you put a multimeter on the battery posts and have someone crank the engine, your voltage should stay above about 10 volts if I remember correctly. If it bottoms out you know that's your problem.
#1. battery/battery connections
#2. Pull all the plugs and repeat #1.
then you can move on to other suggestions.
JMO
Rog
JMO
Rog
