Results 1 to 8 of 8
Thread: Oil Pressure Switch for Electric Fuel Pump
    Littleton, CO
    129
    I’m going to be installing an electric fuel pump on my ‘63 GT in the very near future. Would someone who’s done this post a photo of how you installed the oil pressure switch while still using the oil flex line for the gauge? Many of you are much better “engineers” than I am and I want it to be functional and still look professional and not just slapped together. Thanks!
    Great Falls VA
    3,392
    This is a link to a few notes on installing the Oil Pressure Switch
    http://www.studebaker-info.org/Tech/...OPSS/opss.html
    You can use port on the front of the drivers side head for the switch..
    64 GT Hawk (K7)
    1970 Avanti (R3)
    Jan 2005
    Yakima, Wa, .
    1,542
    I have a switch for an idiot light, not a flex hose, but here's my setup: (it's at the rear of the engine so it's not real noticeable)
    Feb 2011
    Pasadena, Ca
    887
    I used an inertia switch. It receives it's power through the ignition switch. The inertia switch in turn supplies power to the relay. The power supply for the pump motor comes off the ammeter.
    May 2008
    Chatsworth, CA, USA.
    1,456
    I did a friend's '52 Commander just like Bruce did. The "T" makes a nice, neat installation.
    790
    The inertia switch seems like a good alternative, because it would provide power to the fuel pump for the initial startup, (no oil pressure) but will kill the power in any kind of an impact, or rollover situation. With an oil pressure switch, the engine would have to crank long enough to make oil pressure, before the pump had power. Just my two pennies worth.
    May 2008
    1,456
    I used a separate pushbutton (momentary contact) switch to run the pump before startup. Worked great.
    Jan 2005
    Yakima, Wa, .
    1,542
    The oil pressure switch has a terminal that powers the pump when cranking regardless of oil pressure
