Results 1 to 11 of 11
Thread: 1959 Lark Seat Hinge Broke - Now what?
    Commander Member severalsins's Avatar
    Mar 2018
    Portland, OR
    34
    For a lighterweight guy (155 lbs), somehow I managed to break the front driver seat metal hinge that's welded to the seat frame? I was just about to start my car when it snapped and the seat fell backward.The metal straight cracked off in two spots. What do I do now? Try and find a welder to piece it back together - or am I going to have to replace the whole darn front driver seat top?
    Anyone have this issue occur?
    Ronnie | Portland, OR
    1959 Studebaker Lark VIII Regal (Hardtop)
    3,580
    Try a picture so we know a bit more than broken. jimmijim
    Oct 2010
    661
    A good welding shop should be able to repair and maybe even reinforce it , But more than likely you will have to remove the upholstery , Ask me how I know , Ed
    President Member 57pack's Avatar
    Apr 2012
    Hammonton NJ
    2,341
    Had the same issue with my 1962 Lark Daytona Convertible. I removed the seat coverings and had seat bracket welded.
    1957 Packard Clipper Country Sedan
    1965 Studebaker Daytona Wagonaire
    Lt. Col. Jimmy Doolittle
    Mar 2018
    Portland, OR
    34
    Thanks! I started taking apart the seat coverings but really don't want to tear anything, so I stopped after getting the bottom staple-style brackets off and the back insert cover slidden out. It seems like I'm going to have to bend out the long slots the the back cover slides into in order to unscrew another set of bolts.
    Here's photos of the breakage...
    Mar 2018
    Portland, OR
    34
    Quote Originally Posted by jts359 View Post
    Thanks Ed! I'll send photos of how far I've gotten with removing the upholstery later today, and if you have suggestions on how to remove the rest, that'd be great.
    27,518
    I can see that someone HAS been into that seat before, as it is reupholstered.
    1,387
    Matters not if it's original upholstery or new, factory correct or custom.
    Take the seat to an upholstery shop and they can access the situation, remove the fabric and padding without destroying it and repair the frame. If the upholstery shop does not do welding, they will know who does or at least get the fabric and padding off so that you can get the repair done and then have them replace everything.
    Montpelier, VT, USA.
    1,101
    Not sure if this had to do with your seat breakage, but Studebaker issued a Service Letter and reinforcement kit due to problems with some of the seats in 1959.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    Mar 2018
    Portland, OR
    34
    Quote Originally Posted by dpson View Post
    Thanks for sharing! Is there a way to see a larger version of these image attachments? I can't read it in the current size.
    1,101
    For some reason I can't get these larger. If you PM me your email address I'll send them to you.
    Dan Peterson
    Montpelier, VT
