Results 1 to 20 of 20
Thread: Best Chrome Polishing Method & How to Keep Whitewalls White!
    Jan 2017
    Carmel, IN
    49
    I'd like some advice about the best method for polishing vintage chrome. The shiny stuff on the outside of my '51 Champion looks great, but the interior chrome is hazy. What's the best method to spiff it up?
    And how should I keep whitewalls white on new (Coker) tires? What do you recommend?
    1,612
    Try using regular old toothpaste on that interior chrome to shine it up. It has a little bit if very fine polishing compound and then you can put a good chrome polish on to protect it.
    I use a product "Bleech-White" on my whitewalls. I get it at the local auto parts stores. White wall tire cleaner is getting harder to find, as are white wall tires.
    Gainesville, FL
    14,777
    Purple Power works great on whitewalls.
    Silver Hawk Member Chris Pile's Avatar
    6,402
    Wear rubber gloves when you use it. That stuff will take your skin off.
    Mar 2010
    USA
    365
    Be very carful with Bleech-White ww cleaner, it will 'stain/mark' paint on hub caps, ie. Avanti.
    President Member Son O Lark's Avatar
    Oct 2007
    Indy, , .
    819
    409 will work on whitewalls.
    South hills, Pa, .
    597
    I have good luck with Mister Clean soft scrub pads or Scotch Brite and dish washing soap. On older tires not Diamondback used Comet cleanser.
    Jan 2014
    marana, Arizona
    723
    Never Dull will restore your chrome to original luster without the use of abrasives. Leaves no residue to "pick out" of channels. Harmless to plastics. Polishes, removes haze and leaves a protective sealer behind. Works extremely well. Highly recommended.
    Woodinville, WA
    442
    Stop using Comet Cleanser or any Cleanser for that matter on anything, you don't need it and it's not good in any waste water. Simply make a paste out of baking soda and water and use that to scrub anything & follow that up with white vinegar. You'll be surprised at how clean that will get whatever your attacking, wheel stains, kitchen sink stains, you name it. Let the vinegar make it foam up and simply wash the residue away with water.
    R.W. Emerson
    14,144
    Bleche-Wite Tire Cleaner is marketed specifically to clean tires, especially white walls. It works well but, the way it works well is to be incredibly caustic, like Easy-Off oven cleaner. If it can eat the skin off your hands--which it can--it can't be good for the long term life of your expensive classic tires. Just use 409 or Simple Green with a nylon brush and a fine steel wool pad for the tough spots.
    4,875
    The tire companies recommend a mild abrasive, like sand paper, for white wall tires. All of those cleaning products eat/rot the rubber.
    Mar 2008
    Parkersburg, WV, .
    253
    Brillo or SOS pads do a great job.
    Right behind you
    1,877
    I've heard a number of people recommend Coca-Cola rubbed with aluminum foil. I've never tried it.
    What I have used is PB Blaster ( type of penetrating oil) on a soft rag. It works pretty well.
    That's on chrome plated parts, not tires.
    3,717
    Best stuff available. If this stuff won't clean/shine your chrome, nothing will. cheers jimmijim
    Sep 2008
    Frostburg, MD, USA.
    93
    I use Shout stain remover to clean white walls and white lettered tires. Many years ago, I had bought a new Oldsmobile 442 and somehow got a grease mark on the light grey velour seat within the first couple of days. My Mom grabbed her bottle of Shout from the laundry room and proceeded to remove the grease. Afterwards you couldn't tell that it was ever there. From that point on, I kept a bottle in the garage and started using it on whitewalls and to clean my hands on occasion. When washing tires, I spray the whitewalls, wait a minute or two and then wash with the rest of the tire and wheel cover. It dissolves the dirt and cleans without scrubbing. It also is a mild cleaner and does not irritate your skin or damage your car.
    Randy Ridenour
    Frostburg,MD
    1964 GT Hawk
    Jul 2016
    Kearney Nebraska
    146
    I like to use a McGuires Clay Bar on everything from paint, chrome and glass. You would be amazed how clear the glass looks after doing this. I used the clay bar yesterday on some chrome as well as another product. I will get the details on this other product later today. In the picture the left is the clay bar and the right is after McGuires Cleaner Wax. The car was covered in green paint over spray 9347CD6C-810A-4801-8D62-A5673F07D793.jpg
    Jim Kaufman
    Kearney NE
    1952 2R10
    1962 GT Hawk
    1963 R3984 Avanti R1
    Jul 2016
    Kearney Nebraska
    146
    “Brasso” chrome and stainless cleaner.
    Jim Kaufman
    Kearney NE
    1952 2R10
    1962 GT Hawk
    Independence Or 7S5
    2,140
    I have tried many different chrome products but always come back to Simichrome, especially for stainless. Of course, if you can remove the piece, a good polishing wheel and fine compound work best.
    Jan 2014
    marana, Arizona
    723
    Quote Originally Posted by 63 R2 Hawk View Post
    Semichrome comes in a tube as a paste. It is abrasive and leaves a white residual you'll have to remove. Use of an abrasive on antique interior chrome control knobs and switches and door handles is not advised. Again, Neverdull is the preferred product for polishing chrome. It's gentle enough for interior chrome and strong enough to remove blueing from Motorcycle chromed exhaust pipes. Nothing else compares. As the old saying goes:" It's a no brainer."
    Jan 2017
    Carmel, IN
    49
    Thanks for all of the suggestions, re: keeping white walls white. I chose an inexpensive option to try -- a pair of the Mr. Clean Magic Erasers. They can be used wet or dry, but I just dunked them in the dishsoap bucket after I washed the tires with a sponge. One Eraser cleaned two tires. The chemical reaction of melamine, formaldehyde, and sodium bisulfate does a GREAT job on the white wall tires. They look brand new! A good investment for $3.00 and some elbow grease!
    Before -- notice the dirt and grime streaks...
    This is the product...
    And after -- bright and white!
