Results 1 to 8 of 8
Thread: Hawk Padded Dash
    1,117
    Hawk Padded Dash
    Is there a padded dash pad that is available, and will "bolt on" to a 56 Hawk dash?...
    10,401
    Would that require padded bolts?
    5,740
    Golden Hawks HAD a vinyl top pad. So did later Hawks. Just be sure to get the trim on the under side that hides the seam from fiberglass to padding.
    805
    SI has them listed for 56-59, 60-61, and 62-63. The one for a 1960 was $71.00.
    Apr 2012
    princeton mn
    3,065
    I would think any local upholstery shop could build you one with out breaking the bank. They are pretty simple.
    Oct 2009
    Eastern NC
    1,186
    As Brad said, those trim pieces will be the hard part to find.
    Wayne
    "Trying to shed my CASO ways"
    ‚Äč
    Sarasota, FL
    370
    Quote Originally Posted by wdills View Post
    I wonder if this product in a narrow and flat configuration would help with small sheet metal screws to screw into the dash?
    http://www.flexchrome.com/products/extruded.htm
    Bill L.
    1962 GT Hawk
    805
    I think that the extruded chrome moulding could be made to work. I think that mine are only about a quarter inch wide, and I didn't see any of the profiles that were very flat, in that width. Some of the other sizes would look better than not having trim. Thanks for the link.
