Results 1 to 6 of 6
Thread: Photo Request (54 distributor vacuum line)
    President Member wdills's Avatar
    Oct 2009
    Eastern NC
    1,182
    My 54 Commander (232 engine) has a hard vacuum line running from the carb to the distributor. I assume this is wrong, hard to make timing adjustments with the hard line going to the vacuum advance. Asking for someone to post a photo of this vintage engine so I can see what the vacuum line is supposed to look like.
    Wayne
    "Trying to shed my CASO ways"
    Nov 2009
    north fond du lac, wi., USA.
    521
    If Stude was like G/M's, the hard line is correct! -Jim
    Speedster Member
    Mar 2017
    Parkton, MD
    169
    Hard line is correct. Unless the distributor is installed in a non-standard position only slight rotation of the distributor is necessary to correct the timing.
    Oct 2009
    Eastern NC
    1,182
    Wow, wasn't expecting that answer. Makes my life easier. Now all I have to do is find a distributor hold down clamp so it will stay where I want it.
    Wayne
    President Member BRUCESTUDE's Avatar
    Jan 2005
    Yakima, Wa, .
    1,543
    The hard line is slightly flexible in that it is ok to move the distributor as needed for timing.
    Jan 2013
    british columbia
    1,207
    Static set the timing first then bend the line to fit. You should never have to change it after. I have a 63 259 and the line is a solid tube. Once it was set I have never had to move it.
