Results 1 to 6 of 6
Thread: 1948 M5 Gas Tank
    Jan 2017
    Long Island, NY
    5
    1948 M5 Gas Tank
    Hello, seems my 1948 M5 developed a small fuel leak from the tank over the winter storage. I am considering my options to have the tank repaired or to try to find a replacement tank. As my truck is not completely stock( appears stock but Ford running gear) I would consider an aftermarket tank that would fit in original location. Any advice would be greatly appreciated. Thanks in advance for any info.
    7,270
    If it is a small leak, the proper version of J-B Weld might take care of it. If the tank is just too far gone you may have to replace. I saw a post somewhere that a Ford Explorer tank was a perfect fit for a guy with an M series on a Dakota frame. It might be worth a look. I don't remember what year he used.
    Sep 2008
    Delaware, OH, USA.
    693
    If you want to get the original tank restored I have heard good things about Moyer Fuel Tank Renu (http://www.gas-tank.com/). I doubt it is cheap but the result will bolt right in
    Jan 2017
    Long Island, NY
    5
    Yes I have been on their website. definitely a consideration. I did try some jb weld as an emergency fix but am not confident it will hold. Thanks for the info.
    7,270
    Quote Originally Posted by 48studebakerm5 View Post
    If it is a simple puncture a sealant can work. If it is a split seam or the first signs of rust eating through probably not. My dad "temporarily" plugged a hole with Seal-All while we were on vacation years ago. He never had anything else done to it. Never leaked.
    Jan 2017
    Long Island, NY
    5
    I think it might be rust as it has been sitting in the garage for a couple of years. Since truck only appears stock( Ford 6 cyl and 3 spd tranny and ford rear) I'm not opposed to a steel aftermarket tank or a repro tank from something that would fit. I need to drop the tank and assess the situation I guess. Any advice on dropping tank? Thanks.
