Results 1 to 9 of 9
Thread: wheel lugs
    Commander Member
    Jan 2010
    east wallingford, vermont, USA.
    93
    Lightbulb wheel lugs
    curious as to how long studebaker used "backward" lugs. i've had avantis for over 40 years; this '53 was my 1st excursion older and i found out the hard way!
    gfperry
    Dec 2005
    Ferndale, WA, USA.
    27,365
    The 1957 Models were the Last of the Left Hand Thread on the Left Hand side.
    Do some Cars currently have Newer or Older Drums installed or some of each, you bet.
    UPDATE: Also, the STUDS have an "L" stamped into them.
    Champion Member
    Mar 2018
    Bakersfield California
    8
    I just painted my left hand lug nuts red as a reminder.
    My fear is that I forget to tell a tire shop and they bust the left side studs thinking the lug nuts are "stuck".
    DT Holder - Bakersfield CA, USA
    1950 Commander ("Resto-Mod" in progress)
    Apr 2005
    California
    4,355
    MoPar used left hand nuts on the left side of the car for many years.
    Left hand lug nuts are marked, some with a circle on the outer surface, some with tiny divots in the middle of the six points. They can be identified by someone paying attention - not that many people do.
    60V-L6 - 60 Lark convertible
    Sep 2015
    Sweden
    630
    My -67 Jag Mk2 had it as well as manu MoPars I've had & it's old-time racing experiance, I've had later Cadillacs that would've profited by having it, many times I felt the nuts were lose on the left side, the -81 hearse was a heavy car but as we all know GM sell on fashion rather than quality.
    Josephine
    -55
    Champion V8
    4d sedan
    May 2007
    Searcy, Arkansas, USA.
    6,858
    Quote Originally Posted by RadioRoy View Post
    Yep, Mopars were still using left hand threads into the 60s. All our 63,64,65 Chrysler products had them on the driver's side.
    President Member 1954khardtop's Avatar
    Apr 2010
    Pattersonville, New York, .
    840
    International and Wiilys used them as well. A kid working in the local gas station busted a stud on my '63 Willys pick up. The owner cussed him out and replaced the stud for free. I felt sorry for the kid, he started working on cars in the '90s, and had never seen left hand lugs before.
    Dwight 54 Commander hardtop
  8. #8
    Sep 2015
    Sweden
    630
    Funny this, my pal was sitting flat on the ground by the right rear wheel of his Citroen today so I asked him why & he said the nutts were to tight & he's a bit weak from being ill for a while so I losened them for him & then went to the other side... both on left side were quite lose while the right side ones were real tight!
    Hmmm... & yes; he drives hard & long distances.
    Josephine
    -55
    Champion V8
    4d sedan
  9. #9
    Jan 2013
    british columbia
    1,027
    I bought a well made utility trailer and the right side had left hand nuts/studs, this fooled me to a point that I damaged a stud and had to press all the studs out and replace them with right hand studs. I got them from Currie. There are a great variety of sizes in thousandths and I had to look at several to get the right size to press in the hole. I had to remove a small amount of material for a perfect fit. They press in easy and cut their own way in.
