I have a 55 Speedster with the original 6-volt, positive ground setup. I start the car sporadically and have to crank it quite a bit to get fuel to the carb. I think it’s evaporation of the lousy gas we’re now forced to buy. All that being said I think a flow-thru, electric fuel pump is a solution.
Has anyone used the electric pump # 800249 listed in the Studebaker International catalog (pg#185). I prefer to buy from them whenever possible but the catalog info is sparse. I want to use the electric pump only to prime the carb and then shut it off to use the mechanical pump. Of course it needs to be positive ground and flow thru when not energized .
Thanks in advance, Murray
