Off the cuff, does anyone know the number of the Griffin drop in replacement for a '63 Avanti? My original just sprouted way too many pin holes.
Griffin radiator for Avanti
Tags: None
For my Hawk, Griffin did not have a replacement part number, even though they had built several Hawk radiators. It was a low volume item and it wasn't worth their time to develop a set of drawings and assign a part number. They may not have a part number for your Avanti either. I ended up shipping them my radiator so they could copy it. They sent it back to me along with the new radiator. It only cost a few more dollars in shipping and I got an almost perfect fit. I did have to slot one mounting hole about a 1/16". Now I can idle at a traffic light on a 97 degree day with the AC on and the temp never goes above 185.
You probably already know this, but if you want it to look like it should you have to ask for stamped tanks, otherwise you will get the square welded "race car" looking tanks. The stamped tank will not be an exact match to your original, but it will look vintage enough to not look out of place.Wayne
"Trying to shed my CASO ways"
If I remember correctly it was right at $1000. That includes shipping both ways.
Yes you can paint it black. I applied a very light coat of SEM etch primer and then a few coats of Eastwood Radiator black. On the fins I used just enough paint to turn it black. I applied it a little heavier on the tanks so they have a nice uniform coat.Wayne
Thanks. I know that S-I has repro radiators for $650, but haven't asked what material they are, or what gauge. I hear so for other makes can be thin brass and not worth the effort.
And I found a semi-local rad shop that when I told him I could buy a repro, thinks he can recore mine for a little less, with a 3 row core, but needs to see it firstRon Dame
'63 Champ
Originally posted by spokejr View PostWhere is the original leaking from? Two years ago I had mine recored out of preventive maintenance during my car's re-awakening, I had the shop put in a higher density core. Never gets hot.Ron Dame
'63 Champ
