Thats the fun of all this Studebaker stuff and the great people on this forum
1957 Golden Hawk F------in Starter Removel.
Originally posted by 57studie View PostPROBLEM SOLVED!!!
In some ways I feel stupid but then maybe not! ...'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
The starter will not come out of the engine with the front wheels pointing straight!!!
I turned the wheels to the right and the control valve that was blocking everything moved totally out of the picture!
The starter almost dropped out by itself! Well now to replace or repair the starter!!StudeRich
Actually Paul it is very simple, when you mentioned "Control Valve", we all knew you were NOT working on a Stock '57 GH.
(1) It is not a '57, maybe a '58?
(2) Someone has gone to a WHOLE Lot of trouble to remove the entire Saginaw internal Power Steering Gear, Column and all and installed a '58 to '64 Hawk Bendix System!StudeRich
We just went the other way (Bendix to Saginaw) on a '62 GT Hawk to eliminate all the complications (and leaking) of the Bendix system.Howard - Los Angeles chapter SDC
'58 Packard Hawk. A partially restored car that was not completely assembled.
I am really confused now! I bought a Golden Hawk thinking it was mostly stock. I am attaching a photo of what my steering system looks like. Is it wrong for a 57 Golden Hawk? My source is Chassis Parts Catalog 55-58 Studebaker (March 1958). Diagram on page 429. Item 1308-79 (Or 1308-139) is what was blocking me from removing the starter.Last edited by 57studie; 04-01-2018, 01:49 PM.
Originally posted by 57studie View PostI am really confused now! I bought a Golden Hawk thinking it was mostly stock. I am attaching a photo of what my steering system looks like. Is it wrong for a 57 Golden Hawk? My source is Chassis Parts Catalog 55-58 Studebaker (March 1958). Diagram on page 429. Item 1308-79 (Or 1308-139) is what was blocking me from removing the starter.
I checked the 1959 to 1964 Studebaker Chassis Parts Catalog for you to see if there was a Serial Number break/change where maybe a few '57's might have been built with 1958 Bendix Power Steering, but found no such thing.
So, the most likely situation is, this Car was not built with Power Steering, so someone added the much easier to find and install Bendix System from a '58 to '64 Hawk.
The Hoses or other parts may be improperly installed, making Servicing it much worse.StudeRich
Thanks for the info studerich. That is terrible news for me. I wanted a stock 57 Golden Hawk, but it looks like I don't have the stock power steering. Sounds expensive to put back to stock. I will ponder it for a while before I decide to do something. For now I will just leave it as it is.
