I have a 289 installed in my '62 Hawk and I'm not able to get a lower radiator hose that works. I have the semi-rigid hose and it rubs on the generator belt. Was there a pre-molded at on time? I suppose I could make a hose to fit but it needs rigidity to keep from collapsing from the vacuum as water circulates. Also the OD on water pump and radiator is 1 3/4". All thoughts appreciated. Chet445
!962 Hawk Lower Radiator Hose
Tags: None
Take your old rigid hose or a stiff wire bent to the shape you need, to an auto parts store and compare it to the hoses hanging on the racks. I found some foreign car hose to use for the top hose on my 1950 Commander. Many lower hoses had a spring installed to keep them from collapsing.
Third one down. https://www.studebakerparts.com/stud...id=9511.525932
I'm changing to a stainless steel tube with short silicone hoses at the ends; it's a lot cheaper. Around $15.Last edited by bensherb; 03-04-2018, 11:51 AM.
Originally posted by TWChamp View PostTake your old rigid hose or a stiff wire bent to the shape you need, to an auto parts store and compare it to the hoses hanging on the racks. I found some foreign car hose to use for the top hose on my 1950 Commander. Many lower hoses had a spring installed to keep them from collapsing.
I'd like to see a picture of bensherb's solution using stainless and silicone hoses.
I went to NAPA store and found a hose with many bends and turns so I figured I could make a hose that would fit. I needed a hose with 1 3/4 ID on both ends. Well I looked at what I had purchased and I thought it might work as is even with all the bends and turns. Sure enough it fit so I put the reinforcing coils in it. The NAPA part number is 7927. Problem solved. This could possibly help someone. Chet445
Check your local plumbing/hardware store they have a variety of adaptors. I have a 63 259 in my 54 Champion and I am using the original radiator from the 6, I had to adapt top and bottom. The thermostat housing is from a GM and the bottom hose is the original from the 6 with a plumbing adaptor from a kitchen sink. The belt is close but doesn't touch.
Originally posted by chet445 View PostI went to NAPA store and found a hose with many bends and turns so I figured I could make a hose that would fit. I needed a hose with 1 3/4 ID on both ends. Well I looked at what I had purchased and I thought it might work as is even with all the bends and turns. Sure enough it fit so I put the reinforcing coils in it. The NAPA part number is 7927. Problem solved. This could possibly help someone. Chet445
Thanks Much !
The SI lower hose may be a one size fits both Hawk and Lark. It may fit better on Larks, but its pretty close on Hawks. It tends to lay against the frame rail, which I'd prefer over coming too close to the fan belt. I always sleeve that hose on the back side/frame rail side to avoid abrasion, and on the top side, to avoid a loose fan belt wind up cutting into it. I have seen both happen. For a sleeve,I use a piece of old radiator hose, and hold it in place with 2-3 large, nylon tie-ties.
The above procedure is only for driven Studes. Of course TQs would not need a sleeve, since no problems are likely to occur due to minimal operation. There are many examples like that throughout our Studes, when it comes to drivers versus TQs.
