Results 1 to 8 of 8
Thread: Transmission/Overdrive
    Commander Member
    Aug 2013
    Lexington, Ky
    31
    Blog Entries
    1
    Can someone explain to me how the speedometer drive gear can accurately drive the speedometer on 1955 champion with T96 /R 10 OD.. The gear is free spinning on the output shaft when I disassembled the R 10 to replace Transmission and OD seals/gaskets..
    1. My speedometer did work fine before I broke units down.
    2.Shop manual shows Items 42 and 43 as speedometer and governor drive gears
    3. Fig 31 of the shop manual /Parts of the overdrive transmission
    The governor gear cannot be verified as working,, I just repaired and reworked the solenoid, while I have the engine and transmission out.
    Now, is it that the universal joint flange when torque down will pull the overdrive shaft against the overdrive bearing with enough tension to drive the gears. It’s the only way I can see this working.
    I would be very grateful if someone would respond with anything to relieve my mind,
    I get my engine back from the machine shop in 5 days and I would like to wrap this situation up and move on to engine rebuild.
    Thanks in Advance
    Bill
    Apr 2005
    California
    4,815
    The way I always looked at it was that the speedometer gear required so little effort to turn that the driving gear's natural friction with the shaft was enough to keep the gear turning.
    That's a crappily worded answer, so if I think of how to phrase it more clearly, I will edit this.
    60V-L6 - 60 Lark convertible
    Nov 2009
    north fond du lac, wi., USA.
    514
    Most of the ones I've seen have a small pin or a key. -Jim
    Commander Member
    Aug 2013
    Lexington, Ky
    31
    Blog Entries
    1
    thanks RaidoRoy. I will sleep much better tonight!!!
    Nov 2012
    Phoenix, AZ
    1,569
    I'm just happy to have learned a new word today...........CRAPPILY!!!! Now to get into the Funk & Wagnel to get the proper and precise definition of this new, exciting word. They say that if you use a new word in a sentence 20 times, you will never forget it. I pity the people I will talk to tomorrow. Hopefully I will get the 20 times done before Sunday, or church might be very interesting.
    Oh, and to help answer the question on the speedo drive gear, all of mine are so far off that I put a "Speedometer APP" on my cell phone and use it. Guess it works off of GPS.........but it works great and on all the cars.
    Ah, thanks, Roy.....I think.
    1966 Daytona (The First One)
    1950 Champion Convertible
    1950 Champion 4Dr
    1955 President 2 Dr Hardtop
    1957 Thunderbird
    Silver Hawk Member
    Dec 2004
    Trochu, Alberta , Canada.
    5,426
    That's a short-tail T-96. IIRC, the two worm gears, one for the speedo, and one for the governor, are held in as part of a stack comprised of them, the rear bearing, a metal sleeve, and the yoke and yoke nut. Long-tail transmissions used a little steel ball in a recess to lock the worms to the shaft.
    Jan 2013
    british columbia
    1,176
    The drive gear has a square female and the cable is male, it turns the cable via direct drive.DSC07753.JPGDSC07758.JPGDSC07762.JPG
  8. #8
    Jan 2013
    british columbia
    1,176
    DSC07763.JPGDSC07761.JPGDSC07757.JPG Some additional photos, the first picture is the spedo end just to show how it fits on the cable
